Effects of Compression Ratio effects on Power/Powerband
Old Feb 17, 2004 | 07:00 AM
Fastbird93's Avatar
Something I've been wondering. Given the same two motors with the exact same setup, one with about a 9.0-9.5 (something a blower/turbo could go on and work well) compression ratio, and the other with about a 11.0-11.5 compression ratio for N/A. Feasibly, how much of a power difference are we talking about???
Reason I ask is that I *may* be looking at a rebuild shortly if bad news comes on my car. That said, I want to go power adder in the not to far future, and would like to have a motor in place rather than rebuild another one.
Asked this here because I figured I'd get a better answer and it might be useful. Mods move if you deem necessary!!
Old Feb 17, 2004 | 08:31 AM
SStrokerAce's Avatar
It's going to effect your cam selection more than anything. The higher compression motor can take more camshaft and still be a "street" car. Meaning it will be driveable.
If you build it for a blower and put a blower cam in it, it's bascially going to be unimpressive NA but work really well on the blower.
Bret
Old Feb 17, 2004 | 08:34 AM
Fastbird93's Avatar
I was thinking of something like a 224/236, something that's ok on N/A but is ready for a blower. Or, a cam swap prior to a blower/turbo isn't that big of a deal.
Say I go with an 847 or even keep the 224/230. Feasibly how much would I cost myself by going with the lower compression ratio??
Old Feb 17, 2004 | 08:37 AM
Powerwise not as much, but power and driveablity you will suffer on both a large amount.
Old Feb 17, 2004 | 01:57 PM
MaxRaceSoftware's Avatar
approx 10.0 hp to as much as 26 hp gains per point in CR
Old Feb 17, 2004 | 02:09 PM
Fastbird93's Avatar
So what I'm understanding here is that I could be leaving 50ish HP worst case on the table by going N/A with a 9.0 compression ratio. AND driveability would be affected?? Dang, this is going to be a descision.
Old Feb 17, 2004 | 02:12 PM
"ONLY" => if "no" detonation occurs , octane and timing curve are correct for your application
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
surreybrad
Sep 29, 2015 09:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
92_RS_305
Sep 8, 2015 07:47 PM
