Do I need to Mill The Manifold?
Old Aug 31, 2005 | 01:58 PM
Deenasty's Avatar
I recently got my heads ported, and they took .015" off them to resurface them. I also went with a thinner head gasket, which is not .026" thick, and stock gasket was .051" thick. That means we shaved off .040" off both the head and gasket, do I also need to mill the intake .040" or do you think I will be able to get away with it? Thanks!
Old Sep 1, 2005 | 06:15 AM
2NastyZ's Avatar
Re: Do I need to Mill The Manifold?
My suggestion would be to have the intake side of the head milled, that way you can use any stock intake with out a problem. But as with other things there is more ways to skin a cat.
Good Luck
GREEN3112
Feb 10, 2019 09:19 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
bunker
Aug 21, 2015 10:21 AM
karpetcm
Aug 14, 2015 03:02 PM
