digital dash issues with 87 gta/lt1 carbed
Old Jul 12, 2013 | 08:49 AM
bird93bill's Avatar
i am needing help figuring out some issues with a digital dash that at present the speedo is the only thing working properly.i wanted to replace the 305 that came in this car with a sbc 350 i had found.after installing the engine,removing the ecm and harness and putting in a fpr and a thermo switch to operate the fan,i discovered the carbed 350 had issues that required a rebuild.i lucked into an lt1 for cheap and got the gmpp intake for carb and the hei dist from the 350 and installed it.the engine runs great,but i have no oil pressure gauge(the only plug for the sender left with the harness)the temp gauge goes from cold to max hot a few seconds after i start it(i've tried three different sending units)the amp gauge sits at 8 and never moves.the tach moves very little and responds to brake pedal as well as accelerator.even the gas gauge doesnt work and i dont see an odometer anywhere.i have figured the first thing is to get the ecm back in and some of the wiring but i didnt want to put all of it back, just what was necessary for the dash and i figured since i was putting the ecm back in I'd run the trans wires to regain lock up and o.d.(700r4).the same thing was happening when it had the 350 in it,but with a rebuilt lt1 i would like to have the gauges working before i drive it much.i get a little overwhelmed when i look at this harness and try to figure out what to keep and what to cut.some of the gauges should work without the ecm reinstalled but for now they're not.HELP!
mr28
Apr 20, 2016 05:44 PM
Jan 23, 2015 01:13 PM
mr28
Nov 23, 2014 11:11 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
