Detonation and staggered ignition timing
Old Apr 4, 2005 | 11:25 AM
  #16
OldSStroker's Avatar
Re: Detonation and staggered ignition timing
Originally Posted by Lonnie Pavtis
MSD makes a thick reluctor that allows machining it down to relocate each cylinder trigger point to be moved a few degrees either way.
Wire EDM is another nice way to make "odd-fire" reluctors.
Old Apr 4, 2005 | 12:35 PM
  #17
SStrokerAce's Avatar
Sent you Pics....
Originally Posted by WS6 TA
Huh, if I’m seeing right he’s pumping the coolant in through the 4 corners of the intake and through the normal inlet on the front of the block, unless those are blocked off. Is that right? If they were blocked off it would almost make sense to just remotely mount the pump…
The only return appears to be from in between the center 2 ports which goes straight to the thermostat housing…
Yep, block off plate in front of the water entrance to the block.....
In the rules of the contest you can't remotely mount the pump.
The return is from the bottom of the block to the thermostat housing on the front of the intake.
Bret
Old Apr 4, 2005 | 08:46 PM
  #18
WS6 TA's Avatar
It’s a nice way of accomplishing a lot of stuff… I’ll be sure to get one the next time I head out to home depot…
Old Apr 4, 2005 | 08:55 PM
  #19
LOL here. Make that your local machine tool "big box". I like how you think.
If you need one, let me know.
Old Apr 4, 2005 | 09:02 PM
  #20
WS6 TA's Avatar
Originally Posted by SStrokerAce
Sent you Pics....
Ok, here they are… the original were enormous (something like 2k x 2K pixles), so I’m posting edited (lightened…) and shrunk (640x480) versions here, click on them and you’ll get a ˝ the original size (1280x960, plenty big to see any detail) version (let’s see if I can get this to work):
(these will live here till I get around to cleaning, at least months, more then likely, years)
Bret, feel free to comment here.
From the bottom of the block, you mean from in between the 2 center cylinders or something else?
Old Apr 4, 2005 | 09:08 PM
  #21
WS6 TA's Avatar
Crud, I forgot that this board doesn’t seem to allow you to see pics in the thread… Ok, the links above link to the small, 640x480 pic, if you want the bigger pic just remove the “s” right before the “.jpg”
Actually, I just took a better look, looks like the return is actually coming from the drain hole on either side of the block where they normally install the KS...
any idea if in either one of these they have the normal water pump connectoin to the block blocked off? In this second set of pics it really looks like they have it plumbed so that the water flows bottom up like normal, but from the center up instead of from the front bottom back and then up...
Anyone have any input on if this kind of thing is worth doing?
liamcg97
Nov 25, 2019 05:55 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Cam's maro
Dec 28, 2014 09:30 AM
Ari G
Dec 11, 2014 03:21 PM
