Desktop Dyno Cam Help Please!!
Old Feb 20, 2004 | 07:28 PM
njspder's Avatar
i am trying to help a friend of mine develop a 2002 3.8 powered camaro. we are attempting to enter the values of the stock cam to get a starting point for the selection of parts.
my problem is that the stock cam values for IVO and EVC are liste as negative numbers( -20 and -34 BTDC respectively).
does anyone know how i can enter these values in DD2000 ?
i already tried to put in 340 and 326 but the program does not accept them.
later
tim
Old Feb 20, 2004 | 09:18 PM
Stephen 87 IROC's Avatar
You need a file called camquest or a CD called camdisk. It has just about every aftermarket cam profile available. That way you don't need to enter any data. It contains a few stock cam profiles if you know the part number of the cam
Are trying to enter the data with seat to seat timing or .050 lift timing?
Try using the built in cam math calculator.
Old Feb 21, 2004 | 12:42 AM
OneFlyn95z28's Avatar
Yes I agree with the above on not entering the right values for "seat-to-seat' or "0.050".
I did that recntly and it drove me knuts. No mater what cam I entered for my new 427 it would only make 400hp
Old Feb 21, 2004 | 12:05 PM
njspder's Avatar
the specs i have are for seat to seat.
when i tried the built in cam thing it would say i need to enter a "valid" IVO.
thanks
tim
Old Feb 21, 2004 | 12:23 PM
The cam math calculator only needs to know LSA, intake centerline, intake and exhaust duration. Do you know these numbers?
The valve timing points are then calculated from that info.
Old Feb 21, 2004 | 12:30 PM
Send me a copy of the file and I will check it out. must be version 3.10
HarleyZ28
Oct 5, 2015 06:23 AM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
QuickSilver02
Apr 7, 2015 11:12 AM
racecarz28
Mar 30, 2015 09:55 PM
armedtrigger
Feb 24, 2015 08:30 PM
