Degreed Cam, ITS OFF, Now What?
Old Aug 10, 2005 | 01:01 PM
  #16
Deenasty's Avatar
Re: Degreed Cam, ITS OFF, Now What?
I think I may have figured out the problem...I was finding TDC, but not TRUE TDC. I am going to redo it when I get home with the correct tdc tool, not just the dial...Could this be the culprit?
Old Aug 10, 2005 | 03:53 PM
  #17
OldSStroker's Avatar
Yep.
Comp Cams Intake Centerline method is pretty good, especially using a hard stop.
http://www.compcams.com/Technical/In.../Files/145.pdf
Make darn sure you have a problem before you try to "fix" it.
Good luck!
Old Aug 11, 2005 | 05:56 PM
  #18
SStrokerAce's Avatar
The hard stop is the only way to accurately find TDC, this should help you out a ton!
Bret
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
thenewkid
Apr 12, 2015 07:42 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
