DCR with E85?
Old Feb 23, 2006 | 03:09 PM
  #16
LameRandomName's Avatar
Re: DCR with E85?
Originally Posted by markinkc69z
I'm excited by it.
Me too. It's going to let me do a two-step process:
1) This coming "down" season (Yeah. I know... we're not done with THIS one yet.), build the engine for gasoline, with ~10.5 static compression.
2) The following down season, build an entirely new fuel system, seperate from the stock one, add an X-Trim and control the whole thing with FAST.
Old Feb 23, 2006 | 05:07 PM
  #17
AdioSS's Avatar
West South Central Moderator
Re: DCR with E85?
What vehicle are you starting with?
I'm looking at doing this with my 96 impala SS and much later with my 91 caprice. I need to find out what parts in the fuel system that I'll need to change...
Old Feb 23, 2006 | 05:24 PM
  #18
AdioSS's Avatar
Re: DCR with E85?
Originally Posted by Injuneer
From the iowacorn.org (pro-ethanol) website:
You also need to keep in mind that for high performance uses, you need to know the "motor" octane. What is posted above is the typical (research + motor)/2 octane number that you see on the local gas pump.
Fred, thanks for that tip
Old Feb 23, 2006 | 05:31 PM
  #19
AdioSS's Avatar
Re: DCR with E85?
Originally Posted by blkchevyz
anyone know what air fuel ratio you would want to shoot for?
Here is some info I've found out.
Fuel AFRst
E85 stoich 9.765
E85 Max power rich 6.975
E85 Max power lean 8.4687
Fuel injectors should be sized for approx 20% more volume.
According to www.e85fuel.com its 105 octane and that's what we have up here. 1 station in a major metropolitan area and it sells for about the price of 87.
Keep in mind it is not 85% ethanol like you may think, the ethanol itseld is denatured 3-4% with gasoline so you can't drink it. The denatured ethanol then has the gasoline blended into it.
I'm excited by it.
OK, even if it were a 50/50 mix, I would still be very interested. The Octane rating is only half of it. The natural cooling ability of alcohol is very good compared to gasoline. I betcha you could run factory hypereutectic pistons up to 600hp with no problems.
Old Feb 23, 2006 | 06:44 PM
  #20
Re: DCR with E85?
My 95 Caprice.
Dragonslayer, Howards PM rods, Mahle pistons and Trick Flows by Lloyd.
On the fuel system I have decided that the simplest thing is to just put a cell in the trunk and running new lines up front.
I was thinking of this pump with this regulator
I am also considering building a kind of odd intake manifold. Which reminds me... There's a question I need to ask in the advanced forum.
Old Feb 23, 2006 | 06:46 PM
  #21
Re: DCR with E85?
I wouldn't. The issue with hypers is their propensity to shatter when stressed. Forged pistons just deform.
I mean sure, that's oversimplified, but that basic point is accurate.
Old Feb 23, 2006 | 06:58 PM
  #22
markinkc69z's Avatar
Re: DCR with E85?
Howard Stewart has worked on that pump for a long time. I have held one in my hand and it was going to be tested but the design wouldn't fit the mechanical test stand due to an unforgiving clearance issue. My problem with the thing is that it runs off the cam lobe of course which pumps for a fairly long duration every two engine cycles. As far as I know all fuel pump lobes are the same. Now there isn't a huge stroke there and there is no compounding of ratio as its a straight shaft. How is that going to provide a smooth flow of 200 gph?
I guess I really just want to talk to someone who has actually ran one that had some high volume fuel demand. I'm a skeptic I guess.
Old Feb 23, 2006 | 08:57 PM
  #23
Re: DCR with E85?
Well one good thing is that if you do have any questions or problems you can email or talk to the man himself. He has a forum on his site. That's kinda cool.
Old Feb 24, 2006 | 07:53 AM
  #24
blkchevyz's Avatar
Re: DCR with E85?
Fuel AFRst
E85 stoich 9.765
my god thats alot of fuel
Old Mar 8, 2006 | 11:39 AM
  #25
96speed's Avatar
Re: DCR with E85?
Anyone have an opinion on what the max DCR you could run on 104, 110, etc would be?
If 9.0:1 is the limit for 93 octane...
A fraction comparison would be:
9.0:1 = 93
10.0:1 = 104
10.6:1 = 110
However, I have a hunch it is way more complicated than that .
Ryan
Old Mar 8, 2006 | 04:48 PM
  #26
contactpatch's Avatar
Re: DCR with E85?
E85 has 72 percent of the energy content by volume, of
gasoline.
To compare price, multiply the price of E85 by 1.39
and compare to gasoline.
Others have written that even non-FlexFuel
cars can run 20 30 40 percent E85.
in other fuel news,
the federal requirement that RFG contain uxygen,
is being dropped, effective May 6.
Note, some MTBE could still be used in RFG gas,
after May 6. but I thik it will soon be either,
less or none, rather quickly.
Old Mar 8, 2006 | 06:18 PM
  #27
96capricemgr's Avatar
Re: DCR with E85?
The midwest states will just mandate the crap at their level. The masses are too friggin stupid to understand science and would rather believe a line fed to them by a lobby group.
Old Mar 11, 2006 | 06:12 AM
  #28
AdioSS's Avatar
Re: DCR with E85?
9.0:1 = 93
10.0:1 = 104
10.6:1 = 110
Ryan
That's probably a better question to ask that what I was asking
Z284ever
60
Feb 28, 2006 08:54 AM
cdb95z28
Feb 24, 2006 12:42 AM
AdioSS
Advanced Tech
Dec 31, 2005 06:56 PM
arnie
Advanced Tech
24
Aug 14, 2005 08:39 PM
