Dart Iron Eagle pan gasket question
Old May 12, 2004 | 10:19 PM
Brady's Avatar
I'm getting around to buttoning up my motor and I'm wondering about the pan gasket.. The block has spread pan rails, but I don't see a specific gasket listed in the catalogs.. I do see gasket for the rocket block which I believe has spread pan rails, but I don't know for sure if it's the right gasket. The part number for the rocket block is : FelPro 1839 .. Will that work with my Iron Eagle?
thanks
...Brady (aftermarket block newb)
Old May 13, 2004 | 06:57 PM
ZWILD1's Avatar
Dart lists two Moroso oil pans (20193 - w/ trapdoor, crankscraper and windage tray & 20192 - oil pan only) which are made for the Iron Eagle block, and Moroso says these pans will fit both the Dart IE and the Rocket blocks. So I would assume any gasket made for the Rocket pan rails should fit the Dart block as well.
Old May 14, 2004 | 06:42 AM
Mindgame's Avatar
Yes, the 1839 will work on both blocks.
and... check to make sure your machine shop drilled return holes in the lifter valley.
Sounds like you're about to have some fun.
-Mindgame
Old May 15, 2004 | 10:31 AM
Brady's Avatar
Thanks!
There are return holes in the valley with screens epoxy'd over them to keep the big chunks from falling through..
It should be fun, probably scary though..
http://teamprickracing.com/mockupdone/Dsc00839.jpg
Old May 15, 2004 | 03:58 PM
Mindgame's Avatar
Nah! Go on and stick your right foot through the floorboard!
Looks like one hell of a fun car. You've definitely been bitten by the HP bug.
Good luck!
-Mindgame
D1SC383LT4
Jan 1, 2016 01:56 PM
PCLZ28
Dec 24, 2015 05:19 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Queens94z28
Dec 20, 2014 09:11 PM
