cylinder head airflow and it's affect on power.
Old Nov 30, 2005 | 07:30 AM
robertg's Avatar
i've got a queston that has really piqued my interest.
i've got a roller cam 350 block sitting in the garage that i would like to build, and i'm starting to lay out the different parts on paper. i may not even keep this as a 350, i might build a 383 or a 396 stroker out of it
what's got me thinking would be related to cylinder heads. as a general rule, how much airflow is too much for street-driven small block? i'm looking to cross off a couple of heads from my list. i'm pretty sure that a 220cc intake runner wouldn't do me much good for the street, unless i built a stroker 383 or 396.
i haven't picked a camshaft yet, so i'm looking for a general rule for cylinder head flow for street use. something with a cnc runner option would be nice. i can save up more money for that
thanks!
Old Nov 30, 2005 | 07:34 AM
MyShibbyZ28's Avatar
Re: cylinder head airflow and it's affect on power.
Read this thread here.
Old Nov 30, 2005 | 12:22 PM
FASTFATBOY's Avatar
That is a hard question to answer, depends on what you build, what you want, weight of the car..lot of variables that go along with that question. On a 383 a 300 cfm 220cc runner is good to around 7000 rpm, a 270 cfm 195/200cc runner is good on a 355 to the same rpm, a 330 cfm 235/240cc runner on a 396 to the same 7000 rpm....these are BALLPARK numbers....alt of it depends on the rest of the combination.
David
Old Nov 30, 2005 | 06:35 PM
LameRandomName's Avatar
That thread should really be a sticky.
One of the best explanations of "practical" head porting I've ever read.
Old Dec 1, 2005 | 08:34 AM
1racerdude's Avatar
thanks!
Ya can't put to much head on it. For a 383 ya need 300+CFM. 300CFM will make 615FWHP if everything else is spot on.Some of the SB2 headed ones are making 800+FWHP. Don't worry so much about the runner size and get the flow numbers. Ya don't loose low end from the head,ya loose it with a big stupid cam most people put in them.
BIG heads=Smaller cam for the same HP.
People are running SB2 heads on them that flow close to 400CFM and a hell of a lot more runner than a 220CC. Buy the largest head ya can afford and build your engine around them.
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Elcojoe
Nov 17, 2014 10:27 PM
