cylinder head airflow and it's affect on power.
i've got a queston that has really piqued my interest.
i've got a roller cam 350 block sitting in the garage that i would like to build, and i'm starting to lay out the different parts on paper. i may not even keep this as a 350, i might build a 383 or a 396 stroker out of it
what's got me thinking would be related to cylinder heads. as a general rule, how much airflow is too much for street-driven small block? i'm looking to cross off a couple of heads from my list. i'm pretty sure that a 220cc intake runner wouldn't do me much good for the street, unless i built a stroker 383 or 396.
i haven't picked a camshaft yet, so i'm looking for a general rule for cylinder head flow for street use. something with a cnc runner option would be nice. i can save up more money for that
thanks!
thanks!
Re: cylinder head airflow and it's affect on power.
That is a hard question to answer, depends on what you build, what you want, weight of the car..lot of variables that go along with that question. On a 383 a 300 cfm 220cc runner is good to around 7000 rpm, a 270 cfm 195/200cc runner is good on a 355 to the same rpm, a 330 cfm 235/240cc runner on a 396 to the same 7000 rpm....these are BALLPARK numbers....alt of it depends on the rest of the combination.
David
David
thanks!
thanks!
Ya can't put to much head on it. For a 383 ya need 300+CFM. 300CFM will make 615FWHP if everything else is spot on.Some of the SB2 headed ones are making 800+FWHP. Don't worry so much about the runner size and get the flow numbers. Ya don't loose low end from the head,ya loose it with a big stupid cam most people put in them.
BIG heads=Smaller cam for the same HP.
People are running SB2 heads on them that flow close to 400CFM and a hell of a lot more runner than a 220CC. Buy the largest head ya can afford and build your engine around them.
oldschool
Feb 9, 2016 09:21 PM
Chris Anderson
Jan 27, 2015 08:30 AM
