Cyl head & timing
Cyl head & timing
A cyl head is going to take X amont of timing to make the most power with the given set up of an eng...
Now other then a cam change will this affect the timing curve of the eng..if so How and why.
thx
thx
Re: Cyl head & timing
Work the timing at the track or on the dyno. Don't get too hung up on a theoretical "optimum". You're talking about a combination of parts that extend way beyond the engine.
Tune for best MPH at the track.
-Mindgame
-Mindgame
Yes, determining optimal timing is definitely an empirical exercise. IOW, you need to experiment. Variables are huge: barometric pressure, humidity and temperature, fuel used, rod length, CR, valve timing, engine operating temperature, VE, combustion chamber design, bore size, etc., etc.
Rich
Rich
oldschool
Feb 9, 2016 09:21 PM
