custom grind cam request ???
Old Oct 18, 2002 | 04:01 PM
bowtiepwr's Avatar
>What type of information do you need when you ask for a custom grind ? I don't see a cam that fits the profile for my new engine , and I want to get the most out of both the supercharger and engine while still staying emissions legal for the "Peoples Republic of Massachusetts" ... opps I mean Commonwealth of Massachusetts
Later ...
stay safe
Old Oct 18, 2002 | 04:17 PM
LT1 1980 malibu's Avatar
depends on what cam company you choose..Most tend to be vague on a street aplication..
Basic that ive seen comp ask me is weight converter compression head flow at .600 lift(that alwasy makes me laugh, yeah buddie my heads only flow at 600) gears and rpm usage..
Thats why i try to use crower for any cam..Plus their turnaround is faster than comp..They will ask you the above plus tire size transmission gear ratios,and flow sheet data if you have it..Carb CFM intake as well intended rock ratio..
Old Oct 18, 2002 | 04:40 PM
bowtiepwr's Avatar
>Does Crower make a cam for the LT1 (1992-1997) ?
I like the the Crane Cams (had them since my 1970 RS Camaro in high school) , and basically it's going into a bored/stroked , supercharged , fuel injected LT1 , with AFR heads , and a 6 speed tranny .
Later ...
stay safe
Old Oct 18, 2002 | 05:24 PM
Yes they ground my cam for my LT1...Sounds like your buildin a killer engine..
Old Oct 18, 2002 | 05:33 PM
bowtiepwr's Avatar
>Not me ... Nick @ www.nu-tekmotorsports.com is doing all the work .
I just need to put it together and figure out the right cam with his recomendations .
Later ...
stay safe
Old Oct 18, 2002 | 05:44 PM
Mindgame's Avatar
Sounds like he should be making the recommendation to me, considering he's building the engine and all.
One thing I've found about cam companies is that you, 'the next customer on the waiting list', only get to talk to one of their lackeys... who just love to get rid of you by thriowing one of their catalog specials at ya.
On the other hand, if you know a good engine builder that knows some people, then he can actually talk to someone who, first of all knows their $hit and secondly, will work to put them into a cam that fits their needs. I believe there is a big advantage their and I've seen some of that here lately with some of my friend's motors. JMO FWIW.
-Mindgame
Old Oct 18, 2002 | 06:13 PM
bowtiepwr's Avatar
>Don't get me wrong ... Nick had a cam all set for me , but it was a Competition Cam and I only use Crane Cams (personal preference) so he gave me the limitations for the duration @.50 , LSA , and RPM range . I hope that I won't have any problems with their "lackeys" . But I will keep those that are interested wheter or not I get "the hurry and hang up" routine .
Later ...
stay safe
Old Oct 18, 2002 | 10:08 PM
AdioSS's Avatar
West South Central Moderator
what did Nick recommend to you? Why not just compare cam lobess of similar specs?
Old Oct 19, 2002 | 08:06 AM
bowtiepwr's Avatar
>I tried to compare similar cams to the Crane Cams catalog and website , but there isn't one . unless I go with a 112LSA instead of a 114LSA . But won't that affect emissions ?
Later ...
stay safe
Old Oct 19, 2002 | 11:26 AM
Lowend's Avatar
Custom cam
I deal with Cam compaines on the phone every day... for a custom grind its hard to beat Crower.
Call up and ask for Dave, he has spent hours on the phone with me helping to setup cams for some really wild applications.
With Crower you also know that you are getting the best possiable materials.
Noenav
Mar 1, 2019 07:38 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
95maroboi
Jun 7, 2015 12:18 PM
Cam's maro
Jan 30, 2015 09:21 PM
