Couple BBC conversion questions
Old Sep 5, 2004 | 07:36 PM
  #16
rskrause's Avatar
Moderator
Re: Couple BBC conversion questions
Originally Posted by LT1 Bunny
Are you looking for a set of used dart heads or oval ports? I still have my cast iron oval ports.
Dart's, but thanks!
As Stehpen said, an open plenum isn't the most street friendly style of manifold. Better with EFI than with a carb, however.
Rich
Old Sep 5, 2004 | 08:09 PM
  #17
Brady's Avatar
We had a vic jr. on the 540. It's a nice all around intake.
I've also got a single plane oval port intake that's already been converted to EFI, with fuel rails and injectors for sale, if your interested.. Around $400 with injectors.. price a conversion....
The stock tach will run off the coil, but it's too inaccurate to rely on.
question What about making the stock speedometer work with a transmission that doesn't have a speedometer provisions??? We were invited to race in the "World Street Race", but one of the stipulations is that you have a working speedo.. Right now I have the stock cluster with all the gauges working except the speedometer. The Dedenbear case doesn't have provisions for a speedo, so I may need a reluctor and pickup on the driveshaft or something of the likes.. Thoughts???
laterz
Old Sep 5, 2004 | 08:56 PM
  #18
10 seconds's Avatar
You want power from a pump gas street motor, check out the sign.
Old Sep 6, 2004 | 02:09 PM
  #19
MEATHEAD's Avatar
Originally Posted by SAR2K
BMR makes a tubular K-member for this swap. I'm sure this would be a major help in the overall picture especially in the oil pan fitment area. Might even help with headers a bit depending on how quickly the front tubes come down.
After test fitting a few high rise single plane intakes on a local car I can see where a good BBC intake will have some issues with the cowl and possibly the wiper ties. Nothing a little creativity can't solve...
Steve...
Hey SARKY long time no drink... We looked at the BMR Kmember when Brady and I were building my BBC 4th gen. We just didn't feel it was going to be "beefy" enough for the kind of power we were going to put on it.
Don't sweat the wiper issue, you'll be able to keep them. Now you will have to do some surgery on the cowl. As long as you have beer anything is possible....
Old Sep 7, 2004 | 10:51 AM
  #20
Mindgame's Avatar
You should be able to do ~650 hp ~570 lbs-ft easy with a 454, smaller rectangular port heads and a hydraulic roller cam. Not tough at all. The first combination I put together for my 68' Camaro was a 468 with Dart 320 heads, 454R intake and a mild hydraulic (252@.050) nothing special. 655 hp and 571 lbs-ft of torque (from memory but that's close)... very drivable.
Before you consider the dual plane... this "mild" engine made close to 500 lbs-ft at 3000rpm. Now we're talking about a street-car/radial-tire setup.... you may not want too much more torque. Just depends on the rest of your setup. Food for thought.
-Mindgame
Old Sep 7, 2004 | 12:24 PM
  #21
94-3.4's Avatar
-Mindgame
500 ft lbs would be pretty wild on the street, nice for the strip though. I will plan on driving the car quite a bit on the street so maybe a mild single plane would be better to bring that torque curve down a bit. Any thoughts more thoughts on this?
Old Sep 8, 2004 | 10:00 PM
  #22
Slow ET's Avatar
Brady or anyone else, you all have any idea which headers will fit a SBC in a 4th gen... with some massaging of course
Old Sep 9, 2004 | 02:13 AM
  #23
Steve in Seattle's Avatar
SBC? ummm... any LT1 header will do.
Old Sep 9, 2004 | 09:43 AM
  #24
mongse_1's Avatar
Depends on the head though. Exhaust ports vary (i.e. Brodix) on heads.
Old Sep 9, 2004 | 11:00 AM
  #25
Slow ET's Avatar
Thanks guys. Just some upgraded Vortec heads, nothing special. Main concern was the clearance around the steering shaft.
Old Sep 10, 2004 | 07:25 AM
  #26
MRBIGBLOCK's Avatar
Ive Got A Third Gen But I Bought Headers From Ed Quay And There Great Give Them A Call.im Running Canfeild Heads And Im Also Very Pleased With Those My Motor Made 750 On Cnc Ported Canfeilds.quays Headers Were Like 600 Bucks In 2 1/8th Tubes.the Bad Thing About Hookers Was You Could Only Get 1 7/8.it Wasnt Raely A Bad Swap And The Results Are Awsome.Quay also acomadated for the raised ports off my heads.
Old Sep 4, 2005 | 01:05 PM
  #27
BLWN1's Avatar
So did you all use a motor plate? Would an lt1 6spd work with a BB, anyone?
Old Sep 6, 2005 | 09:40 PM
  #28
MEATHEAD's Avatar
Brady yes, Me no.
Yes I think a BBC/6spd could work.
Old Sep 9, 2005 | 07:14 PM
  #29
BLWN1's Avatar
Did you use a BMR k?
Old Sep 10, 2005 | 02:01 PM
  #30
Brady's Avatar
No, a PA k-member. these were race cars. the bmr has the poly motor mount things, or at least it did back when these cars were built.
