Coolant fitting near siamesed exhaust ports
Old Dec 13, 2004 | 12:43 AM
7zark7's Avatar
I have a set of aftermarket heads that have what looks like a provision for a coolant fitting just above the middle siamesed exhaust ports (i.e. cylinders 3&5 and 4&6). Right now it's capped off with a plug. I figure getting extra cooling on the paired exhaust ports is probably a good thing, so I want to use it if it's useful. What do you guys think?
If I wanted to use it, where would I plumb a line to? It's for an LT1 so it's reverse cooled if that matters.
TIA.
Old Dec 13, 2004 | 11:47 AM
SStrokerAce's Avatar
Re: Coolant fitting near siamesed exhaust ports
Yeah that coolant line is to help cool off the heads in SBC/LT1 setup since it's an extremely hot spot in the heads. It's a old trick that's used on GM 23 and 18 deg heads.
You would plumb a line from the top of the water pump where it enters the block out to there on each head. Usually it's a small AN like 4.
Bret
MadMav
Feb 6, 2015 11:02 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Sandersen511
Jan 13, 2015 03:49 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
