Hydraulic roller questions
Old Dec 13, 2004 | 02:28 PM
12Second3rdgen's Avatar
I am currently running a hydraulic flat tappet camshaft, specs are:
274/280ADV, 230/236@.050, .487/.490 lift
Setup is as follows:
Vortec headed 350, 10:1, mild head work, single plane intake, 750CFM carb, 1 5/8" headers
I wanted to go to a small solid roller camshaft, but I am looking at a lot of $$$ to make that happen. What do you guys think of hydraulic roller setups? My biggest concern is that it isnt going to RPM like my current hydraulic flat tappet. I have heard hydraulic roller setups have a tendancy to run into valve float in the upper rpms. I would be shifting this motor around 6500 rpm. Can I make a hr setup work without spending a ton of money on a rev kit? Will an oem style hr lifter support this kind of rpm? Is an oem style lifter more likely to cause valve float than say a Comp XE hr lifter?
Thanks guys!
Old Dec 13, 2004 | 02:49 PM
Boost It!'s Avatar
Re: Hydraulic roller questions
correct geometry, spring pressure and rev kits can do a lot. I revved to ~7k with no valve float. regularly. 7500 hurt stuff...
Old Dec 13, 2004 | 03:07 PM
AutoRoc's Avatar
I've never seen a Rev Kit that was pricey really. Can you run a 1.46" spring on that head without machine work? Studs pressed in or threaded? I know what you mean about converting to safely run a SR cam and if the same amount of work is required for your heads to do a HR, then I'd suggest just doing a whole new top end. I am doing the same sadly.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Roadie
Feb 16, 2015 10:34 AM
Red_94Formula
Jan 22, 2015 12:17 AM
siguy
Nov 27, 2014 10:07 AM
