Converting heads
Old Aug 27, 2004 | 08:38 PM
kevsbird's Avatar
Converting heads
I am in the process of building a max effort LT1. I want to put some gen-1 type heads on it. Who converts SBC heads to LT1 blocks? Thanks
Old Aug 27, 2004 | 09:24 PM
1racerdude's Avatar
Re: Converting heads
PM me for details.
Old Aug 27, 2004 | 10:41 PM
Mindgame's Avatar
Harden Motorsports
-Mindgame
Old Aug 28, 2004 | 12:31 AM
SStrokerAce's Avatar
Part of the issue with this is making the water passage and the oil drainback so they are completely sealed off from one another. Best way would be to get the coolant right and sealed off completely then press a piece of bar stock thru the head, weld that in and then drill it out for the oil drain back. That and the deck surface has to be changed to match the block.
It's not like it's going to be fun and only worth it when you goals can't be met by something like a AFR 215RR.
Bret
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
StansZ28
Feb 19, 2015 07:39 AM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Geoff Chadwick
Jul 31, 2002 12:07 PM
