383 Windage tray
Old Aug 17, 2004 | 01:28 PM
PostalZ's Avatar
383 Windage tray
I'm looking to get a windage tray on my 383 stroker. When we took it all apart, we saw it didn't have one. Anyone here have a stock tray on a stroker motor? If no, someone shoot me a recommendation for a good midpriced/budget pan that has a tray to clear my scat stroker crank.
This rebuild is taking longer than expected
Old Aug 17, 2004 | 02:59 PM
WS Sick's Avatar
Re: 383 Windage tray
I just bought the Milodon diamond screen tray, and trimmed it to fit the crank, there were actually only a few places that needed to be tweaked. The stock pan fit on with mild adjustment as well.
Old Aug 18, 2004 | 12:19 PM
R_Andersen's Avatar
I'm running the stock windage tray with an Eagle 383 crank and Eagle H-beam rods. I ended up using ARP main studs for the 400 SBC to give the clearance required and even still, the pan required some modifications with the hammer to clear the rods, but it will work.
-Rob A.
Old Aug 18, 2004 | 10:06 PM
Formula03's Avatar
I used the miloden as well and with a little trimming it fit nice. Although, if you want to try and modify a stock one I have one Ill sell for $12 if you need on.
Old Aug 19, 2004 | 03:09 AM
PostalZ's Avatar
$12? i'll take it. Maybe buy a milodon as well... know any place that stocks one that i can have by saturday?
Old Aug 19, 2004 | 10:00 AM
WS Sick's Avatar
I bought mine from Jegs, if they have it in stock they can over night it to you.
Old Aug 19, 2004 | 05:15 PM
bad95formula's Avatar
Im running the Miloden windage tray in my 355 and it fit like a charm!
Old Aug 25, 2004 | 12:00 AM
lillbush5555's Avatar
What about the Moroso 23020??
Matt
Old Aug 25, 2004 | 08:19 AM
WS Sick's Avatar
Isnt that basicly like thefactory one? I see part #s in my research, but no pictures.
Old Aug 28, 2004 | 10:47 AM
mrz28 73/97's Avatar
I've got a Milodon Diamonds Stripper in my 383 and all I had to do was elongate 1 bolt hole and trim for the dipstick tube to pass. I also have both the Canton oilpan and a Milodon 7qt.
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
smoknta
Aug 27, 2015 05:07 PM
alphaauto
Jul 26, 2015 04:40 PM
