Converting Gen 1 heads to work with Gen 2 Block
Old Jul 28, 2002 | 05:56 PM
LJ93Z28GM's Avatar
Post Converting Gen 1 heads to work with Gen 2 Block
Is it possible and if so what is needed to be done to use gen 1 heads on my gen 2 LT1 block. I will be using an old school dual plane as well.
I am converting to carb and distributer. I know you are going to possibly say why not just use a gen one block and save the headache, but i already have a freshly built LT1 block currently running in the car.
Old Jul 29, 2002 | 04:03 PM
sseeya's Avatar
Post
If the only reason you are thinking about doing this is because you want to convert to carb and distributor why don't you just use the LT1 or LT4 carb manifold that GM Performance Parts makes.
SSEE YA,
Mike Glick
97 SS #2476
12.678@110.49
383 in the works!
Old Jul 29, 2002 | 06:45 PM
LJ93Z28GM's Avatar
Post
I am also going to switch my heads. I am planning on a set of AFR's but do not wanna spend the extra cash for the LT1 version heads. The range of intakes and head selection opens up on a large scale if i am able to convert them to my gen 2 block.
Old Jul 30, 2002 | 06:02 PM
sseeya's Avatar
Post
I'm pretty sure it can be done, but the question is: Is the extra range of heads and intakes worth the added expense of converting Gen 1 heads to work on your LT1 block. Unfortunately, I don't have the answer to that question.
SSEE YA,
Mike Glick
97 SS #2476
12.678@110.49
383 in the works!
Old Jul 30, 2002 | 06:58 PM
Tokuzumi's Avatar
Post
Compare the cost of converting the heads, vs buying the LT1/4 versions (speaking of AFR heads), and see which one costs more. If you are doing the work yourself, then it's pretty much a no brainer, but if you are paying someone, it's something to look into.
Old Jul 30, 2002 | 08:17 PM
big worm's Avatar
Post
do a search in this forum under lti victor heads. this was discussed a few weeks ago.
Old Jul 31, 2002 | 01:40 AM
Soma07's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by sseeya:
</font>
I think it all comes down to much the conversion would cost.
For instance looking at AFR's catalog a set of 190cc LT1 heads is $1750. While their SBC 190cc Street Heads are $1250. From the pictures and descriptions provided they both appear to be identical except the LT1 head is designed for reverse cooling.
So in this case it appears you could save some money provided the coversion was less than $500.
Jason
93 TA, M6
Old Aug 2, 2002 | 09:32 PM
millican's Avatar
Post
Here's a article of the conversion a while back out of a magazine.
http://www.lt1intake.com/LT1_retrofit.htm
EDIT- opps, sorry that link is the other way around.
86 Camaro Sport
LT1 Induction
383 Speed-O-Motive Crate Engine, Raptor 700R4 Transmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
LT1 Intake Website
Moderator at SE ThirdGen
[This message has been edited by millican (edited August 02, 2002).]
parkers Z28
Mar 11, 2016 08:14 PM
MadMav
Feb 6, 2015 11:02 PM
Catmaigne
Dec 25, 2014 12:16 PM
Jul 4, 2005 05:00 PM
JasonD
Jul 15, 2002 02:17 PM
