Conversion for Brodix heads?
Old Oct 26, 2002 | 02:09 PM
  #16
94-3.4's Avatar
647hp na?
that is increadible. So you actually got a distributor to fit in an fbody? More and more ideas keep popping into my head for a killer 350. If i were to run Fast, i could run any small block chevy block?
Just to build a sweet 350 with distributor, fast, killer heads, custom intake, etc would be increadible. What did you do for exhaust manifolds too?
thanks for all the info
Goose, yellow? I saw one in fort collins that was a yellowish orange with a fuel pressure gauge on the hood once and it sounded pretty mean. Prolly not it though.
Old Oct 26, 2002 | 03:28 PM
  #17
Madhu's Avatar
Originally posted by Darren94Z
I am looking to sell the Brodix heads. Here are the specs
-10
fully ported
2.08 intake
1.60 exhaust
spread port exhaust
Brand new guides, seats, valves, springs, retainers ect..
The only thing that isn't new is the aluminum castings themselves
they flow around 335/240 @ .700 lift
Make me a offer on them if you want them
Darren
I know I shouldn't be but I am - very interested. You've got mail.
Madhu
Old Oct 26, 2002 | 08:53 PM
  #18
jimlab's Avatar
Originally posted by 94-3.4
647hp na?
647 on the base maps, so far. Final tuning hasn't happened yet, because we're waiting on a converted front cover with a cam sensor to finish the FAST eDist setup. That's also with a big dip through the point at which peak power should have been (~6,900 rpm). The engine recovered after the dip to ~637 hp out at 7,400 rpm before falling off.
The only other things you need (besides the eDist and a cam position sensor) are a crank trigger and 8 LS1 coil packs, pretty much. The engine isn't being built for an F-body, which is why I had space restrictions.
SLP 1 7/8" primary headers with an off-road Y-pipe.
Old Oct 27, 2002 | 11:27 AM
  #19
94-3.4's Avatar
That sounds like a sweet setup. You are making that kind of power with 1 and 7/8" headers too. That really gets me thinking. I am going to look into fast with edist and possible go that route when i build my 383 or 396. So many ideas now. Thanks again for the info!
Old Oct 27, 2002 | 11:58 AM
  #20
jimlab's Avatar
1 7/8" long tubes on the dyno, actually, but I don't have the clearance for long tubes in the car. I expect that output will drop somewhat with the "shorties", but that's more than acceptable. The car will only weigh around 2,750 lbs. or so.
Engine:
http://www.c-zone.net/markm/JimLaBre...o/P1010114.JPG
Old Oct 27, 2002 | 12:03 PM
  #21
94-3.4's Avatar
Jim, your engine is a work of art and all i can say is wow! Please let us know what you run at the track when it goes in. Thanks for all the info again!
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Queens94z28
Dec 20, 2014 09:11 PM
Elcojoe
Nov 17, 2014 10:27 PM
