Cometic gaskets?
Old Jan 18, 2005 | 06:18 PM
Black95Form's Avatar
Cometic gaskets?
Anyone using cometic gaskets with a street car. Wondering how they seal? Real life experience would be appreciated.
Michael
Old Jan 18, 2005 | 06:57 PM
captaindbol's Avatar
Re: Cometic gaskets?
There was a pretty good discussion on here this week.
http://web.camaross.com/forums/showthread.php?t=332020
Old Jan 18, 2005 | 06:58 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
i have a pair slightly used, if you want them, i went back to copper, just personal preference i guess.
if you are interested mike i can sell them to you cheap!
let me know.
Old Jan 18, 2005 | 07:13 PM
rskrause's Avatar
Moderator
Deck and head must be smooth and flat. Otherwise, they will seep. If you are running very high cylinder pressures thye are a good choice, otherwise don't bother.
Rich
Old Jan 18, 2005 | 09:35 PM
Rob(94Hawk#319)'s Avatar
Rich
Is 12:1 Compression and a 200 shot enough cylinder pressure to require cometic gaskets?
Old Jan 18, 2005 | 09:37 PM
taner's Avatar
Rob
imo...yes
Old Jan 18, 2005 | 09:39 PM
Shawn 97 Z28 M6's Avatar
Texas Moderator (1998-2009)
I'm running 1074's w/ close to that (160rw worth of N2O ).. And they're still intact. Even after 3 years. I've got a set of cometics in the garage waiting for a new motor buildup for boost + N2O however.
Old Jan 18, 2005 | 09:40 PM
rskrause's Avatar
Moderator
I ran 14lbs of boost and a 200hp nitrous shot with FelPro #1074. YMMV.
Rich
Old Jan 18, 2005 | 09:44 PM
Thanks for the reply guys... Since the block is still in the car and only the heads are getting freshened up, I'll stick with the Fel Pro's and try them out, I've used them so far, and only sprayed playing around on the streets... When I took the heads off, the gaskets looked pretty much brand new.. If/when they go, I'll step up to the cometics if I don't trash everything and go LSx variant in the Hawk.
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
pepon214tx
Sep 20, 2015 04:48 PM
