Can you put L-31 heads on a lt1?
Old Sep 5, 2007 | 12:48 PM
95lt1a4's Avatar
Let me try to make this simple so I don't look completely dumb.
I have a 383 rotating assembly and an lt1 block that have all machine done for sale.A friend called me and asked if I knew if you could bolt a set of L-31 heads on a lt1 and if not would my rotating assembly work on the truck style block.I'm pretty sure the rotating asssembly will work in the truck style block(one piece seal as well). I don't know for sure about bolting the heads on a lt1 block though.The water jackets look a lot different.Does anybody know?
Old Sep 5, 2007 | 06:46 PM
96capricemgr's Avatar
The Vortec heads are equivalent to iron LT1 heads on the b-bodies. The cooling is different so they are not easily used on the LT1 block.
The "LT1" rotating assembly would be the right one for a one piece rear main truck engine.
Old Sep 5, 2007 | 10:16 PM
95lt1a4's Avatar
Thanks.I did a search and saw where you can have machine work done to make the heads work,but I told my friend that it wasn't worth it.
Old Sep 5, 2007 | 10:22 PM
jerminator96's Avatar
Definately not, tell him to just use the other block with that rotating assembly. I'm not sure that L-31 heads would be able to feed a 383 anyway, depends on how high it's spinning and his power goals I guess.
Old Sep 6, 2007 | 06:37 PM
The L-31 heads flow as well as the best of the as cast LT1 heads, not saying that is right for a 383 but saying that they are a very good factory head.
Old Sep 6, 2007 | 06:44 PM
Well that's what I was saying, it's just not enough for a 383 in my opinion. But again, that depends on how high he is going to spin it and his power goals. Heck he might be going with a blower, in which case headflow numbers matter less.
oldschool
Feb 9, 2016 09:21 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
NewsBot
Dec 28, 2014 06:20 PM
Queens94z28
Nov 20, 2014 06:03 PM
