Can someone explain the differences of Solid roller, and hydraulic motors for me????
Old Jul 24, 2002 | 10:46 PM
ford's Avatar
Post Can someone explain the differences of Solid roller, and hydraulic motors for me????
Cant find this anywhere.
I want to build a 396 in the next few months but i know so little about Solid roller and hydraulic motors i dont know which would better suit me. Nor what the differences between the two are. How they function, make their power, efficiency, sound, reliability and so on.
Someone just please educate me!
I want to do a 396 NA and dont know really how to start.
Old Jul 24, 2002 | 11:01 PM
kmook's Avatar
Advanced Tech Moderator
Post
I've given some info about this over in LT1 Tech over the last few weeks.
Basically you'll need a:
a solid roller- cam, lifters, springs, locks, retainers, and longer pushrods (usually 7.8" unless you use a longer valve).
A solid roller will in general make more power than a hyd roller. It can have steeper ramps than a hyd because of the lifters and springs that are used. A solid roller will drive better too, i had no cam surge at all with my large solid roller without tuning.
You will have to adjust valve lash every few thousand miles, usually 3-4, whereas with hyd you dont have to. And with a solid you will have to replace the springs probably once a year, depending on how much the car is driven.
Also I am probably putting my solid roller setup for sale, so if your interested
But this would fit better in LT1 Tech, so i'll move it there.
Thanks.
Ken Mook - 97' SS #2544
Advanced Tech Posting Guidelines
  • ?rwhp & ?rwtq Naturally Aspirated on the Stock Bottom End.
  • Stage 3 Pro Performance Heads, Solid Roller 242/248 Cam, Endur-X Lifters,
  • Jet Hot Hooker LTs, True Dual 3" Exhaust with x-pipe, and the list goes on and on...
[This message has been edited by kmook (edited July 25, 2002).]
cmyname1
Feb 19, 2015 08:38 PM
95chwagon
Jan 13, 2015 09:19 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Wicked
Jul 25, 2002 04:19 PM
Ed95Pont
Jul 23, 2002 08:26 AM
