can this head be repaired?
Old Sep 19, 2004 | 11:53 AM
blk1994z's Avatar
http://www.cardomain.com/memberpage/283449/3
i got a set of heads off my buddy and he dropped a valve and it damaged the head as you can see in the last 3 pics. Is there anyway it can be repaired? Or is the head junk now? The other head is fine, the heads have some work done to them.
Old Sep 19, 2004 | 01:08 PM
bunker's Avatar
Re: can this head be repaired?
Yes they can be repaired, just go to a shop that does alluminum welding & they'll weld a big blowb on there which you can shape.
Old Sep 19, 2004 | 01:43 PM
NOMAD's Avatar
I've got a head in similar shape... Actually, much worse
I did find that mine was warped from the contact, so the head may be junk if you aren't able to take enough off the bottom to true it up. Even then i'm not sure if the intake seal or anything will suffer. I would have someone check to make sur eit's true before having any welding done.
I do have my other head left over if you would like to buy it. It's ported and stuff, so i'm not sure if you would be even interested.
-Shannon
Old Sep 19, 2004 | 04:46 PM
blk1994z's Avatar
pm'd you nomad
Old Sep 19, 2004 | 05:44 PM
oil pan 4's Avatar
Those are nice.
If you take it to most any shop they should beable to fix them.
I don't think any of them will tell you to use it as a boat anchor.
I have seen worse heads than that brought back to life.
Old Sep 19, 2004 | 05:48 PM
blk1994z's Avatar
ill take them to a shop and see what they say than.
Old Sep 25, 2004 | 07:49 AM
limige's Avatar
if anyone has a set of junk lt1 heads let me know, i'm looking for some to do mock up assemblies.
thanks,
mike
Magenta_Hearts
Mar 25, 2015 10:24 AM
nikolt1
Feb 27, 2015 09:10 PM
NewsBot
Feb 26, 2015 02:10 PM
Jazsun
Dec 29, 2014 12:14 PM
