can billet be distinguished from forged by appearance
Old Jul 21, 2005 | 05:49 PM
D3kennedy's Avatar
such as cranks, rods, etc? thanks,
dk
Old Jul 21, 2005 | 07:09 PM
SStrokerAce's Avatar
Re: can billet be distinguished from forged by appearance
cranks most times yes... some rods like a H beam no, because they are fully machined forgings which are actually stronger anyways.
Bret
Old Jul 22, 2005 | 01:37 AM
jimlab's Avatar
I don't know if this is always the case, but the forging line was clearly visible on my Cola crankshaft (see arrows) and my Crower billet ultralight had none.
http://home.gci.net/~jimlab/images/Misc/crankshafts.jpg
Old Jul 22, 2005 | 02:43 AM
MaxLean's Avatar
That one on the left is beautiful!
Old Jul 22, 2005 | 06:26 AM
D3kennedy's Avatar
thanks for the pics, it shows a very good comparison. I have seen the casting lines on "cast" products but i didn't know that forgings left the same.
dk
Old Jul 22, 2005 | 08:26 AM
N20Dave's Avatar
I'm not sure about the billet vs forged issued but as for the statement above, cast vs. forged, they both have a parting line. On the end of the counterweight, the one on a cast crank is a thin line and the one for a forged crank is a wide line.
Old Jul 22, 2005 | 10:14 AM
OldSStroker's Avatar
The Cola forged crank in the pic appears to be a "twisted" forging. It's forged in one (two-piece) die as a "flat" or 180* crank, and then the two middle throws are twisted 90* while the forging is still hot.
A non-twisted forging is formed in a couple of dies. One does the nose and rear flange and the outer throws, and the other does the inner part. The forging is turned 90* when moved from one die to the next.
Some folks think non-twsted forgings are stronger. They are usually more costly.
Old Jul 22, 2005 | 12:58 PM
Z28SORR's Avatar
Ok, you have me confussed, not hard to do. In the pic. of the Crower "billet" crank there is a very distinct "cast" line that can be seen on the last rod throw. I thought billet ment the item was totally machined from a solid piece of material?
Old Jul 22, 2005 | 01:14 PM
jimlab's Avatar
You're evidently seeing something that I'm not. Are you sure it isn't just the reflection off the machined surface?
I thought billet meant the item was totally machined from a solid piece of material?
It does. In this case, a ~350 lb. billet of 4340 chromemoly, which is one of the reasons the cost is so high.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Bobczar
Oct 23, 2015 11:22 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
