cam for my 355, good choice?
need to order a cam TODAY, and haven't had any response in lt1 tech, so i'm trying this.
called combinatin motorsports, they recomended this cam for my 355 lt1
233/239 569 lift on 110 lsa
can be custom ground to whatever i want.
how does that look? i pretty much want to go as big as i can on my 10.6:1 compression, 6 speed, and is a weekend driver. don't want to rev above 6500 rpms
any other suggestions welcome!. thanks
-Jason
-Jason
Re: cam for my 355, good choice?
Whether you have responses there or not, it should be discussed there. Your thread is only a day old... also you can try to TTT it to get some attention.
Thank you
PS. I like the specs on that cam, but it all depends on your setup and what you want the car to do. CM is usually pretty good as far as picking out a cam for a customer. If you are worried you might not get the optimal cam for your setup, go to someone who can spec you out a true custom cam.
Thank you
