Broken crank whats compairable to cola
Old Sep 27, 2006 | 01:57 PM
  #16
Camaro_Guru16NY's Avatar
Re: Broken crank whats compairable to cola
Originally Posted by jerminator96
Well I've never heard of a metal that you "couldn't drill." Unless he makes them from Adamantium
isnt it unobtaniam or something like that lol
-john
Old Sep 27, 2006 | 03:01 PM
  #17
jerminator96's Avatar
-john
All jokes aside though, anything that can be machined can be drilled, plain and simple. Unless there is some surface treatment after the machining that would make it harder than anything we have to drill with, it is just not possible. But like I said before, it is much more likely that you "can't" drill it without messing up the coatings that he applies to his cranks.
Any of you knowledgeable machinists have any input? I'd love to be wrong about this.
Old Sep 27, 2006 | 04:28 PM
  #18
streetbad's Avatar
Case hardening -Very hard to drill,easy to grind.
Old Sep 29, 2006 | 11:16 AM
  #19
MachinistOne's Avatar
I agree with OldSStroker that you should be using a more ridgid aftermarket block. If you are experiancing block flex(which I don't see how you are not) then that can lead to crank failure, stronger block will extend crank life.
I agree with Eric@VRE that the Callies Dragonslayer would be fine for this application.
I have only had the pleasure of working with fewer than 10 HTC cranks, they are NICE pieces, as for drilling them, that should only be a problem in relation to the oil-shedding coating only in the area that you have heated and drlled through it.
realistyc
Jul 28, 2015 07:32 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
94Form
Jul 17, 2015 10:56 PM
Catmaigne
Jul 14, 2015 05:17 PM
Fastbird93
Jul 11, 2015 04:37 PM
