this board
Old Jul 19, 2002 | 04:26 PM
DukeofBird's Avatar
Post this board
i posted in here about some pistons for a .060 over and .125 stroked 400 engine (which would make 426 cu in) and it got moved to the third gen board. this is a stroker engine and is very difficult to find pistons for. after being moved to third gen, which i had already posted on before, it got only one reply. i didnt appreciate this being this board is supposed to be for strokers and such so i am going to try this one more time. i want to know if anyone knows of any manufacturer that makes .060 over pistons for a 400sbc with a 3.875 stroke crank(stock is 3.75) and 6.0 rods. thanks in advance.
1984 project bird 2.5/ 5spd, soon to be 400+cu in smallblock/th350
Old Jul 19, 2002 | 04:40 PM
Kev@ramchargers's Avatar
Supporting Advertiser
through 1/28/03
Post
Wiseco, and JE both offer pistons for that stroke and rod combo, however the biggest off the shelf bore is 4.160. From what I saw you will need to have a custom piston made.
Hope this helps
snoochie woochies
Old Jul 20, 2002 | 02:41 AM
kmook's Avatar
Advanced Tech Moderator
Post
I will leave this thread here for you this time.
And I'm not trying to be a hard *** but there are some rules:
Taken from the Rules, Policies, and Disclaimers Page
<font face="Verdana, Arial" size="2">
We reserve the right to close or delete any message for any or no reason whatsoever.
When a post is locked or deleted, it is for a reason. DO NOT UNDER ANY CIRCUMSTANCE make another post in continuation of the locked/deleted posts or your account is subject to being banned. DO NOT UNDER ANY CIRCUMSTANCE make a new post demanding explanation of why a post was locked or deleted. If you would like explanation of a closed or deleted post, e-mail the moderators of the forum in question.
</font>
Thanks.
[This message has been edited by kmook (edited July 20, 2002).]
Old Jul 20, 2002 | 06:42 AM
DukeofBird's Avatar
Post
i am sorry that i went against the policies and reposted this but i had already posted pretty much the same message in the third gen board and recieved no reply. a friend of who has been a member for quite a while told me to try the advanced board because it has more info on strokers and such, so i also posted it here, and it was moved to third gen within 24 hrs.
Old Jul 20, 2002 | 08:28 AM
strokedTA's Avatar
From: Where people don't discriminate about your induction system.
Post
Quit looking for off the shelf ppistons and call the companies.
Most of them make custom pistons: Mahle, CP, BME, Weisco, Ross, Diamond, JE, Venolia, and so on, just to name a few.
Good luck
Dave
If a little's good,
More is better,
And too much is just right!!!
Old Jul 20, 2002 | 01:40 PM
kmook's Avatar
Post
Duke,
No problem. Reason i moved it the first time was even though it has to do with strokers i didnt feel that it was that advanced. Just an FYI.
Like the others said best bet would to be just to call these companies and see what they have, or have custom ones made.
Old Jul 20, 2002 | 10:15 PM
unstable bob's Avatar
Post
unstable bob sez:
I'll say one thing...there are DEF a lot of strokers on this board...
P.S. I've had good luck with Ross pistons for my insane flights of fancy.
"unstable bob" gable, JAT, MON.
AMERICAN ROAD WARRIOR!
1979 Trans Am/455 Olds
1973 AMX/360 AMC
bunker
Jan 30, 2016 08:09 PM
Daluchman1974
Sep 11, 2015 06:12 AM
TGGodfrey
Aug 17, 2015 08:43 PM
KYWes
Aug 10, 2015 07:03 PM
