Block Q.
Old Jun 22, 2005 | 03:20 AM
aboadnan's Avatar
Block Q.
Sbc up to LT1:
When does it have to be filled?
If it is half filled, can it be streetable (ie overheating)?
Thanks.
Old Jun 22, 2005 | 07:23 AM
rskrause's Avatar
Moderator
Re: Block Q.
No simple answer to the first question, but blocks with partial fill can certainly be used on the street. I do it.
rich
Old Jun 22, 2005 | 02:35 PM
aboadnan's Avatar
Re: Block Q.
Thanks very much for your quick reply.
Old Jun 23, 2005 | 01:18 AM
TheNovaMan's Avatar
Re: Block Q.
Rich, how much fill do you put in? What brand do you prefer? Electric or mechanical water pump?
Old Jun 23, 2005 | 09:20 AM
rskrause's Avatar
Moderator
Re: Block Q.
I have used the stuff from Moroso and Hard Blok, both seem to work fine. Obviously, for a street motor you want to do a "short fill" - to below the level of the water pump holes. I have used both a mech and an elec WP with partially filled blocks. There is very little heat in the lower part of the block. However, OTOH I am not sure how much stability is added with a short fill. So, this begs the question of "should I do it?"
Rich
Old Jun 23, 2005 | 02:31 PM
LameRandomName's Avatar
Re: Block Q.
Originally Posted by rskrause
...I am not sure how much stability is added with a short fill.
Rich
I'm sure it's not a perfectly linear relationship, but I would have to imagine that if Block Fill helps at ALL, then a half fill will give somewhere around half the stiffness.
I have nothing to base that on of course, but I can't imagine that a half-fill wouldn't have a significant effect, even if it's nowhere near what a full fill would.
You'd think someone would have done some testing on this by now...
Old Jun 26, 2005 | 02:00 PM
TheNovaMan's Avatar
Re: Block Q.
No kidding.
Does block fill just help stabilize the cylinders, or does it make the bottom end (mains) more rigid too?
GREEN3112
Feb 10, 2019 09:19 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
heus
Sep 8, 2015 12:01 PM
