Big VATS problem car wont do anything
Old Oct 3, 2003 | 02:17 PM
Ponykillr's Avatar
I recently put a T/A dash in my Z. When doing so i took out the A/C, Heater, Airbags driver and passenger and the radio. There are a lot of things unpluged no down there but i know for sure the VATS module is plugged up (black box green plug).
The problem is when i connected the battery the security light was on along with every light that could light on the instrument cluster. so i turned the key fans work lights work (plugged the radio in again it worked) but when i went to start the car the PCM fuse blew.
The fuel pump never came on and the starter never engaged and the security light stays on.
Anyone know what i should check to get this thing to start? I also cant seem to find the VATS relay what do the wires look like going into it?
Also the Key seems fine chip is not dirty and the security light is on before i even put in the key.
Old Oct 3, 2003 | 02:42 PM
kmook's Avatar
Advanced Tech Moderator
This should be discussed in a gen spacific forum. Since it is already being discussed in the correct one (LT1 Tech), I will close this.
Thanks.
MadMav
Feb 6, 2015 11:02 PM
ChrisFrez
Nov 30, 2014 08:41 AM
Louey
Pacific
Nov 28, 2014 03:46 AM
USAirman93
Nov 24, 2014 03:37 PM
GigaMp3z
Feb 20, 2003 02:57 PM
