big cam + small heads
Old Jan 5, 2004 | 10:31 PM
  #16
AdioSS's Avatar
West South Central Moderator
Originally posted by AdioSS
I was looking at Comp XE lobes 3196 & 3318 with 1.6s on the exhaust on a 115 LSA. I've got an AFR rev kit, Comp R liftters, and won't cheap out on the springs. I want peak power around 6500 and good vacuume with decent gas mileage.
The heads might not flow so great at that much lift, but they are still flowing air. This just means the peak airflow will be reached more. Or maybe that's just how I think of things. I might try 1.5s on the exhaust to get "only" .563" exhaust lift.
OK, I've got a chance to get a used cam that's almost exactly what I want. There are only 3 differences.
I would've chosen the 3196 lobe for the intake and this one has the milder 3316.
lobe -- adv - .050 - .20 -- lift - - 1.5 - - 1.6
3316 - 288 - 236 - 157 - .347 - .521 - .555
3196 - 288 - 236 - 162 - .390 - .585 - .624
I would've chosen to get it on a 115LSA and this one is on a 114 (not too big of a difference)
I would've chosen to get it ground with Zero advance and this one has 4* advance ground in.
I just don't know... The price is VERY appealing, but hmm... I don't know... My cam would have top end that meas I'd have a better chance of getting the trap speed I want. This one would be better for around town driving.
Old Jan 7, 2004 | 11:40 AM
  #17
SStrokerAce's Avatar
AdioSS
Big diff in lobe area between those two cams. Might want to take that into consideration.
That and I'm not a big fan of that wide of a LSA, either the 114 or 115.
Just my .02
Bret
Old Jan 12, 2004 | 01:02 AM
  #18
dist0rtion_69's Avatar
so, it's an 84 Z28 with a T56 behind a SBC. How big is the motor?
It is a 357.
What's the compression ratio?
~10:1.. iron heads
hydraulic or solid, roller or flat lifters?
hydraulic cam, flat lifters
What's the lobe seperation?
I believe that would be a 110Lsa.. Partly responsible for some of
the drivability issues.
Advanced or retarded valve timing?
Advanced, as to how much I can't remember exactly. The car doesn't
detonate as I believe the cam bleeds off alot of compression.
One more thing, what rear gear ratio and what diameter tires are you running?
245/50/16 right now and 3.42's.. Have had 3.73's.. Not a huge difference
between the 2.. New rear has 4.56's, but haven't had it installed yet.
Not my choice to run 4.56's, because thats what the used rear had in
it I bought.. I will probably try runnin them with a 275/40/17 BFG Drag at
the track until I get some slicks for this car.
As you can see gearing will probably help my probs a bit.. I also just took the
284h cam out in favor of a 274h..Its only a 2-3 hour job to do cam and
lifters.. I figured why not The 284 was just too much for now until I get some
better heads.
Peace,
Old Jan 12, 2004 | 11:20 AM
  #19
AdioSS's Avatar
Originally posted by dist0rtion_69
I run a 240/246 cam on vortec heads that have had a little
work done to them and 2.02 valves. They are protopline 170cc
heads. The cam is .507/.510 or so. The car really needs some
heads, IMO. After feeling the topend pull of my LS1 and comparing
it to this car. It really suffers on drivability at low rpms (which with the
t-56 you will notice) but it feels like it just runs outta breath
past 6k. Don't get me wrong.. it still pulls hard, but it feels like it
reaches a climax at 6k, and just sorta holds steady til 6500-6800.
It is a 357.
~10:1.. iron heads
Advanced, as to how much I can't remember exactly. The car doesn't detonate as I believe the cam bleeds off alot of compression.
245/50/16 right now and 3.42's.. Have had 3.73's.. Not a huge difference between the 2.. New rear has 4.56's, but haven't had it installed yet.
Not my choice to run 4.56's, because thats what the used rear had in it I bought.. I will probably try runnin them with a 275/40/17 BFG Drag at the track until I get some slicks for this car.
As you can see gearing will probably help my probs a bit.. I also just took the 284h cam out in favor of a 274h..Its only a 2-3 hour job to do cam and lifters.. I figured why not The 284 was just too much for now until I get some better heads.
OK, now we're comparing apples to oranges
My case vs yours
383 --- 357 CID
11.5 -- 10.1 CR
alum - iron heads
roller - flat tappet
EFI ---- carb?
I'm interested in seeing how the 4.56s work behind your motor.
Old Jan 13, 2004 | 02:30 AM
  #20
That we are.. but it still relates to the topic.
Peace,
Old Jan 17, 2004 | 09:02 PM
  #21
Vicious95Z28's Avatar
I won't run my mouth alot b/c it's been a while since I've posted but I'll say this, "The faster ya go the more it takes". Low end is your friend, if you don't want to spin buy some tires but @ 4100#s you need all the bottom end you can get. Too much camshaft is only going to make drivability suffer, and put your power where you can't use it. I recently discussed this issue with a gentleman concerning the cc306. Very popular, but he said you'll hate it below 4000 R's. Basically it'll make you not like it very much when you drive it.
later,
Vicious
Old Jan 18, 2004 | 12:16 AM
  #22
nosfed's Avatar
later,
Vicious
Just got a buddies car done a few weeks ago. It's a 94 with 11.96:1, balanced 357 with home ported heads, normal bolt-ons and a 306. The idle is choppy, but not obnoxious, and the car pulls like hell from around 2800 to about 6800. With the ceramic coatings, it doesn't detonate at all on 91 octane. This particular car needs tuning and is running pig rich, but the cam isn't really offensive to me. If you like the quiet refined ride of a Lexus over the rumble of a hotrod, you'll not like it.
Old Jan 18, 2004 | 01:28 AM
  #23
AdioSS's Avatar
later,
Vicious
I might be totally wrong, but I think the weight of the vehicle shouldn't have near as much impact on building the engine that everybody seems to think. yes, I know my car is pretty darn heavy. However, with the extra 33cubic inches and a good bit more compression, I should have more power everywhere in the RPM range than my stock engine no matter what size cam I go (to an extent!)
Others have gone with cams of similar size in smaller engines and loved them! Yes, my car is heavy and needs torque to go, but why not move the torque band to the right where I can also pick up horsepower?
Assuming the only changes to an engine are the duration specs (same LSA, same lift, same everything else in the engine) it should be able to put out X peak torque, right? What's wrong in moving that torque peak up and gaining horsepower at the same time?
If you are right about this being too much cam, then I'll put 4.56 gears in the big boat
rideordie
Nov 5, 2019 04:52 PM
oldschool
Feb 9, 2016 09:21 PM
MadMav
Feb 6, 2015 11:02 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
jmzlt1
Mar 13, 2003 07:26 AM
