Balancing Question
Old Mar 4, 2008 | 12:43 PM
ulakovic22's Avatar
Balancing Question
I have a quick question concerning balancing a rotating assembly. I've never personally done it so I don't know.
Do you weight all the components seperately and then pair them (rod/piston) with each other so that the bobweight is equal or close to it on each throw or do you weight them all and get an average bobweight and then just drill or add heavy metal to balance?
Old Mar 4, 2008 | 07:45 PM
MachinistOne's Avatar
The rods and pistons are balanced(ground or drilled) to match the lowest weight in the set - that sets your number to put on the balance card. If you just take averages you are really not balancing anything.
Old Mar 4, 2008 | 07:56 PM
mdacton's Avatar
within 2 grams correct? piston/rod bearing and ring set....... Just want to verify.
I have seen it done many times but noone ever explains anything to me
Old Mar 4, 2008 | 08:10 PM
ulakovic22's Avatar
What exactly are you trying to balance? One cylinder to it's counterpart or just the whole receipocating mass on the crank so it's smooth? Won't doing the former automatically cause the latter? If so then why are people able to use weighted flywheels and balancers?
Old Mar 4, 2008 | 10:58 PM
Stephen 87 IROC's Avatar
Rods are balanced at each end to match the weight of the lightest one. All the big ends are weighed the same, all the small ends are weighed the same.
All the wrist pins should be matched to the same weight. It's very difficult to change their weights. If close enough but not exact, the pins can be match weighted to the pistons so a specific pin must be used to a specific piston. If the weight difference of the wrist pins is too great, different pins need to be used to get a set close enough to the same if not exact.
Once the rods have been adjusted to the same end weights and the pistons/pins have been adjusted to the same weight, their weight is added to the weight of the rod bearing, rings, rod bolts/nuts and pin locks if used to get a total weight for the bob weights.
It's just about impossible to do a proper backyard balance job. You just don't have the proper balancing jigs and you have no way to spin it up to check the bob weight balance on the crank.
Spending $500 to get your rotating assembly balanced properly is worth it. When I had mine done, the balance sheet showed it was spun up 8 times to get a perfect balance.
Old Mar 4, 2008 | 11:36 PM
Rather than typing a long explanation out...
http://www.babcox.com/editorial/ar/eb10330.htm
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Newgmman
Feb 25, 2015 02:53 PM
Jason Short
Jan 19, 2015 06:33 PM
