ARP Mainbolts and line boring
Old May 24, 2003 | 07:29 PM
RabidDog24's Avatar
I just had my block line bored for trueness, can I replace the standard main bolts w/ ARP bolts and not have it affect the line up of the caps?
-Rabid
Old May 24, 2003 | 07:41 PM
rskrause's Avatar
Moderator
Re: ARP Mainbolts and line boring
-Rabid
Yes, but you need to fit the crank and check the clearances and that it rotates easily anyway.
Rich Krause
Old May 24, 2003 | 07:53 PM
RabidDog24's Avatar
Re: Re: ARP Mainbolts and line boring
Rich Krause
Yeah that is ness. anyway I was just wondering if since the ARP bolts have a much higher torque rating, they might drive the crank journal closer to the bearing, thus throwing off the alighnment.......
-Rabid
Old May 24, 2003 | 08:50 PM
OldSStroker's Avatar
Re: Re: Re: ARP Mainbolts and line boring
-Rabid
Because of how studs work, there may be less, not more block distortion with the studs. The best way would be to align bore or hone with the studs, but the slightly different clamping loads of the studs shouldn't change anything, but check anyway as Rich said. Make sure you use APR's recommended procedure and lube when you assemble:
http://www.arp-bolts.com/media/pdf_f...9-31_36-37.pdf
Old May 26, 2003 | 06:10 PM
turb0racing's Avatar
Your only using ARP bolts not studs. You should have no problem.
Old May 27, 2003 | 11:35 AM
Eric Bryant's Avatar
Changing from one brand of bolt to another should not cause a problem, as others indicated. If you're really concerned, then you could torque them to the same value as you used with the previous set of fasteners - anyone see a problem with that? I'd still recommend going with ARP's recommend torque and double-checking the bearing clearances - I really, really doubt that you'll have any problems.
HectorM52
Jul 30, 2017 11:46 AM
Jasonz28camaro
Jun 7, 2015 09:14 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
