Any progress on the OPTI alternative
Old Jan 1, 2010 | 07:40 PM
  #166
DirtyDaveW's Avatar
Sometimes. The problem is that the optical sensor can get fouled by that crap that flys off the rotor and posts so you never really know. I test my opti OFF the motor before putting everything back on. Just disconnect all the fuel injectors (the pulsing of the F.I. is triggered by the opti), hook up the opti connector, the coil, turn on the key and spin the rotor with your fingers. You should hear the snap, snap, snap from the spark plugs if all is well. After that, put it back on properly.
Originally Posted by maddog05
Unless things have changed, electricity still flows from negative to positive.
My question is: when an opti starts to sputter can we get good results by replacing the cap and rotor ...especially when the symptom is identical to condensation in an old style distributor? Like on rainy days with cool nights on a 1977 chevy v8?
Old Jan 4, 2010 | 03:20 PM
  #167
Pampered-Z's Avatar
The post that refuses to die: Originally posted 09-18-2002, 03:18 AM.
If only our opti lasted this long!
Old Jan 7, 2010 | 02:26 PM
  #168
marshall93z's Avatar
290,000+ miles on mine.
Old Jan 7, 2010 | 02:27 PM
  #169
Mikes 1994 z28's Avatar
Got 73k on mine
Old Feb 16, 2010 | 11:24 AM
  #170
mzgp5x's Avatar
I purchased a used Accel DFI Gen 7 system. Attempting to make the move to opti-less, since, I have not had much luck with them (6 failures and 3 failue modes). So, I have launched a new project to keep my mind active. I know now what Ingineer was saying about the cam signal. But, I think I have my own simple solution since I have access to a machine shop and alot of old opti parts. Thanx for your valuable info. (97ss 383 - D1 MM6) B.
Old Feb 16, 2010 | 11:32 AM
  #171
Highlander's Avatar
http://www.eficonnection.com/eficonnection/default.aspx
Hit where it says 24x. That is the opti alternative.
Old Feb 16, 2010 | 06:37 PM
  #172
Savannah Dan's Avatar
Yikes! 2 grand. I'll be keeping my opti.
Old Feb 17, 2010 | 11:21 AM
  #173
DirtyDaveW's Avatar
+1... Well, my opti and my LTCC.
Feffman
Oct 9, 2015 05:42 AM
Feffman
Jul 2, 2015 06:52 AM
Gtpguy
Jan 26, 2015 04:50 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
