AFR210 and Edelbroch TPI Hiflow base possible?
Old Dec 15, 2004 | 11:00 AM
BoGo's Avatar
I'm considering the AFR210 head for my upcoming 381cui with a S-trim. I would like to keep my SR and the Edelbroch Hi-flow baseplate but I fear that the intake ports on the AFR head are to large for the Edelbrock (not sufficient wall thickness and sealing surface). The size of the Edelbrock port is 1.25 X 1.98 and the AFR port is 1.31 x 2.18 so I'll have to grind a bit. Anyone done this combo? What about sealing surface, wall thickness, welding necessary?
I could have measured it by myself but the intake is on my old engine right now (still running..) and I hate to remove it if it's not absolutely necessary.
Goran
Old Dec 15, 2004 | 12:12 PM
Dave69Z's Avatar
Re: AFR210 and Edelbroch TPI Hiflow base possible?
Goran
You might have better success getting an answer at www.thirdgen.org 's messageboard.
Dave
G-BODYT56
Jan 14, 2022 11:14 PM
RX Speed Works
Oct 1, 2015 10:19 PM
surreybrad
Sep 29, 2015 09:00 PM
drt
Sep 27, 2015 04:39 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
