AFR 210's Pushrod length?
Old May 21, 2005 | 11:26 PM
Highlander's Avatar
Anyone know?
I would like to know if htey are longer or stock...
Valves are stock AFRs.. 0.050 longer i think.
Old May 22, 2005 | 01:46 AM
atljar's Avatar
Re: AFR 210's Pushrod length?
Im running stock length with unmilled AFR heads, but my block is also very decked.
Old May 22, 2005 | 03:27 AM
1racerdude's Avatar
Originally Posted by The Highlander
Anyone know?
Ya gotta measure it with adjustable push rods and soft springs. Ya need to get the geometry right with the marking on the valve stem.
Every set up is different so don't count on anybody else's length to work.
Old May 22, 2005 | 03:47 AM
bunker's Avatar
exactly, I took a lifter, took the stuffings out of it and put a screw inside then put the top back on to make it solid, bought a comp cams adjustable pushrod, put just the inner valve spring on and a piece of tape on the valve stem, adjusted the rockers, turned her over once and saw where the roller had rolled on the valve, closer to the exhaust side of the head = too long, closer to the intake = short, just int he middle is where you want it. Then read what the pushrod says and buy that pushrod.
Old May 22, 2005 | 03:57 AM
1racerdude's Avatar
The middle is OK but I like to get the smallest width pattern and get is as close to the middle as ya can.Just my preference.
Old May 23, 2005 | 10:38 PM
bunker's Avatar
Umm.. Yeah the middle.
Old May 25, 2005 | 01:33 PM
mongse_1's Avatar
I had standard 7.2s in my motor until I put a checked in for piece of mind. I ended up getting some 7.3s. Nothing too crazy..232/236, .600/.612 @114 cam, minimal milling to the heads. I'll check again when I put the new cam in it.
Old May 25, 2005 | 05:37 PM
Highlander's Avatar
That is interesting... i will measure mine pretty soon.. starter will be wired when i get some time from school
G-BODYT56
Jan 14, 2022 11:14 PM
13qtr
Oct 28, 2016 08:11 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Bigtoyz97
Sep 21, 2015 01:44 PM
realistyc
Jul 28, 2015 07:32 PM
