absolutly best 23* sbc head??
Old Sep 23, 2005 | 01:36 AM
  #16
1racerdude's Avatar
Re: absolutly best 23* sbc head??
Originally Posted by MachinistOne
W351 Ford race block to 408 cubes (per 400" spec)
4v cleveland canted valve heads
FRPP 351c to 351W manifold
If you are running a max effort stock valve angle/port placement class, it's all about the ford symetrical port/20deg heads. (for small blocks) Chevy's can't match the flow...
Ya can go further with a set of Blue Thunder's. .Mine would flow 396CFM on a 4.030 bore,410 on a 4.125 bore. Ya can use an aftermarket head in his class as long as the valve angle is +/-1* of factory.
Old Sep 23, 2005 | 01:46 AM
  #17
SStrokerAce's Avatar
Yeah once you get a Cleveland it's all over..... Then again a Victor Edelbrock can do 400cfm but it's not -1°
Bret
Old Sep 23, 2005 | 01:51 AM
  #18
1racerdude's Avatar
Bret
They can NOW with Glidden's design and Chapman porting. Those BT's were doing that in '99. Done by Richard.
Old Sep 23, 2005 | 01:47 PM
  #19
Canted Valves help a ton eh!
Too bad these Ford Racing classes don't let real Chevy heads in, all you have to do is give them some 18° and 15° stuff and it would be just as competitive.
Bret
Old Sep 23, 2005 | 07:00 PM
  #20
AutoRoc's Avatar
Chris' post here came to mind when I seen this thread.. Maybe worth looking at?
http://yellowbullet.com/v-web/bullet...pic.php?t=3309
Old Sep 23, 2005 | 07:12 PM
  #21
lt1camaroman93's Avatar
now that's a killer combo, Figureing my car is heavier, the nitrous would make up for that and that's the times i'm looking to be at. It's just to bad I don't have the money right now to buy them or I would.
Old Sep 23, 2005 | 07:24 PM
  #22
1racerdude's Avatar
Like I said earlier the All Pro's will get ya there,if ya got the money. They are serious heads.
Old Sep 23, 2005 | 09:19 PM
  #23
MachinistOne's Avatar
Yeah - I've got a set of blue thunder's on the race motor that has been sitting waiting for a car, makes about 550rw. I have a lot of cleveland parts, couple original 4-bolt main blocks, 4 sets of 4v heads...but yes, give the chevy's some 18deg stuff and it's competitive again.
Old Sep 23, 2005 | 09:29 PM
  #24
1racerdude's Avatar
That "race motor" a 408?
Mine made 611RWHP@8000RPM's on motor.I used all the thunder them heads had.
Got an '89 Mustang with a little work(from setting) it could be ready. It's been in the 8.3's on W tires and has a moly cage.Bring that bad boy down and I'll put it in.
Old Sep 24, 2005 | 10:22 AM
  #25
Chirs is one hell of a engine builder, so no dobut those are bad *** heads. Tony @ BES finished 3rd last year in the Engine Masters, either way both of those boys know their stuff.
Bret
Old Sep 24, 2005 | 12:17 PM
  #26
stealthblack's Avatar
871 from a 413 with standard[ish] angle heads and no sheetmetal. impressive!
i do 4 years and engine technology has the audacity to move on without me. heaven help me when i try to put together a competitive BBC.
that deal has to be spinning to what, 9 and change?
like i said ive been out of it, can a super Vic keep up with that combo or is it holding it back.we used to have to hog a vic jr. to 1206/7.
Old Sep 25, 2005 | 08:37 AM
  #27
n20ta2's Avatar
Im using Dart Pro 1's with the cnc port. 23 degree head uses stock valvetrain (or stock configuration shaft mount like im using)flows over 300 cfm @600 lift and I paid 2900 for them ready to go.They have serious potential when ported additionally too.
Old Sep 25, 2005 | 10:57 AM
  #28
Denny McLain's Avatar
What kind of intake do you have and what kind of rwhp power are you making with the Darts?
Curious as I'm currently in the market for more aggressive heads and intake as we aren't getting the power we expected from a set of Trick Flows that flow 260@.400 and 300 @.600. Think..... THINK, it's the intake that's killing us, but we're not positive.
Was planning on a set of raised runner heads but the issue of valve train expense, reverse cooling (except AFR's), and porting really adds to the already high cost and I'm not sure what we will be getting out of the deal.
Old Sep 25, 2005 | 02:12 PM
  #29
It's a circle track motor, so I stayed with a stock stroke in case it ends up in a class with stock displacement rules. 351", I have a callies 408 crank for it in case all the tubing laying around starts forming it'self into a sprint car chasis, where I can run the extra inches.
I would love to see it run in something, it has been sitting on the shelf for 3 years.
Old Sep 25, 2005 | 03:00 PM
  #30
1racerdude's Avatar
Ya know, I have been waiting for that second shift to get off their *** and do something around here,but it ain't happening. I've got two projects that have been sitting for several years and it would be nice if they were finished too.
