99 Corvette LS1 swap into 95 Z28
Old Aug 12, 2002 | 10:15 AM
SuperDave479's Avatar
Question 99 Corvette LS1 swap into 95 Z28
My LT1 has 150k miles on it but my cousin said he'd sell the LS1 to me for $1200 that came in his 99 Vette. It only has 33k miles on it. I have an A4 transmission. What all would I need and would it fit with the stock hood? Also, is it possible to use a 93-97 SS hood with the LS1 and have it functional?
'95 Camaro Z28 A4
Oynx Black, 3.23 gears, T-tops, RKSport CA-300 ground effects, 17X9.5" polished 2000 C5 wheels on P275/40R17 BFGoodrich g-Force T/A rubber, Flowmaster 80 Series exhaust with chrome rolled edge quad tips, aftermarket two-tone leather seats (got the original cloth ones recovered), white face gauges and red bulbs from MacEwen, "diamond clear" clear corners, blackouts on taillights, chrome CAMARO letters on rear and "chrome" painted Z28 logos (looks like shiny silver) and vents on the hood, 97+ Camaro console, interior changed from Light Gray to Dark Gray.
My webpage
F-Body wallpaper
First, check Brent's Appearance Guide then check
SuperDave's supplement Appearance Mods pics for more 4th gen F-Body pics.
[This message has been edited by SuperDave479 (edited August 12, 2002).]
Old Aug 12, 2002 | 11:20 AM
kmook's Avatar
Advanced Tech Moderator
Post
I did a search for you and found these discussions , Did you look at these?:
http://web.camaross.com/bb/Forum30/HTML/000942.html
http://web.camaross.com/bb/Forum1/HTML/109082.html
Ken Mook - 97' SS #2544
Advanced Tech Posting Guidelines
  • ?rwhp & ?rwtq Naturally Aspirated on the Stock Bottom End.
  • Stage 3 Pro Performance Heads, Solid Roller 242/248 Cam, Endur-X Lifters,
  • Jet Hot Hooker LTs, True Dual 3" Exhaust with x-pipe, and the list goes on and on...
[This message has been edited by kmook (edited August 12, 2002).]
Old Aug 12, 2002 | 11:37 AM
Post
<font face="Verdana, Arial" size="2">Originally posted by kmook:
</font>
Yeah, one is talking about the truck LS1 and the other they won't answer his questions because they keep talking about cost. Thanks for doing the search though. I'll post a new one in the LT1 Tech section.
Old Aug 13, 2002 | 08:19 AM
Gripenfelter's Avatar
Post
My uncle buys lots of written off F-bodies and he screws around and sees if he can make hybrids.
He told me the clearance problem with the hood is near the front at the throttlebody.
You might wanna look at a cowl hood or an Ultra Z hood.
You also need an LS1 torque converter.
'93 Camaro Z28 Automatic with a ZL1 hood.
No bottle.
No blower.
383 cubic inch serving of horsepower...hold the rice please.
Thats all you need to know.
ICQ: 23984221
Gripenfelter's Homepage
Disclaimer: The opinions expressed by me are not necessarily supported or indicative of the Government of Canada or any other Federal Employee.
Old Aug 13, 2002 | 09:56 AM
Pro Stock John's Avatar
Post
Try the conversion/ hybrid forum on www.ls1tech.com.
Motor will clear fine, you need the harness, motor mounts, and some other stuff.
1998 Formula | ARE 422ci iron block with Stage II heads | 40 lb Injectors | LS6 Intake | TTS headers | 3" ORP | Mufflex 4" Catback | MSD Wires | Whisper lid | SLP MAF | FLP level IV 4L60E | Yank TPE4400 | Moser 9"/4.10's | RT Torque Arm | HAL Shocks and Springs (front) | V6 Springs (rear), Alston 8 pt Rollcage | Airlift Airbag | Weld Prostars | ASCD Hood | 11.15@120.30mph 1.53 3625 raceweight LS1TECH.COM
Old Aug 23, 2002 | 01:06 PM
BOOST FED 95Z's Avatar
Post
Hi, That was my post about the 6.0 ls1. I checked into it alot, one thing that bothered me was that I couldnt use the intake off of the truck, the other was the cost and fabrication that would have to be done in order to make this a clean swap. I stuck with my lt1. Keep me updated I would like to see how this swap goes. I definately think it would be a good one.
Scott
1995 MYSTIC Z28
M6
T-TOPS
CHROME Y2K VETTE WHEELS
VORTECH S-TRIM
AFTERCOOLER
CC306 CAM
1.6 RR'S
HOOKER LT'S
MUFFLEX 4"
CHASSIS ENGINEERING 8 PT.
HARWOOD 2.5" COWL HOOD
NITTO 275-40-17 DR'S
Old Aug 23, 2002 | 02:36 PM
LT1Brutus's Avatar
Post
The Corvettes have a throttle-by-wire setup. You would need to either get the electronics from the vette to accomodate this or you would need to get a different throttle body of an LS1 camaro/transam. Also, the bellhousing would need to be changed on your tranny. Like the others said you need the motor mounts, torque converter,etc. I think you may in fact need the entire K-frame that the motor mounts are attached to but I'm not sure. Further, I don't know if the camaros/corvettes had the same exhaust manifolds are not, you'll need to research that and either get them off a camaro or go w/ headers for a camaro. Don't forget that your current y-pipe, cats, cat-back wont work though the cat-back could be modified. The only clearance problem would be w/ the intake normally used on LS1's. You could do some minor fabrication w/ plastic or metal tubing and make the 96SS style intake funtional, I don't know what it's clearance between the LS1 and stock hood would be though. Personally I'd recommend a 99style WS6 intake w/ your choice of after market lid etc topped of w/ an SLP Ultra-Z hood. I've seen several guys w/ the U-Z hood modify their LT1s to use the better design of the LS1 intake. The reason I say to use the WS6 one is that it has a larger intake area than any of the others. Another thing to check would be the accesories/locations on the 'vette versus camaro/ta. I know the vette has a totally different steering rack and so it might also have a different pump. Also I'm pretty sure the vettes accesories bracket places the AC, alt. ps pump etc in different places than the camaro but I'm not postive of that. You'll also need to figure out what to do w/ the EGR system, it was different of vettes than f-bods....pesonally I'd have custom programming done and get rid of it. While you're at it go ahead and get the LS6 intake manifold and if you've got some exta flow ($) put a cam in that sucker. Please email me and keep me posted on this swap as my buddy wants to do the same thing.
Black 95 Z28. Chrome Z-5 spks, MSD coil, BBK shytty headers, 2800 Vigilante, CAI, free mods, !MAF, !ESC, !CAT, !AIR, !EGR, !21 bolts, Ken's Perf. tranny, 13.05/105.5 before following mods.
Complete 3.73 rear end w/ T/A girdle,LT4 HOT cam,springs,1.6 Comp cams RR's. New times to come
Old Aug 23, 2002 | 02:39 PM
Post
Wow, thx for the replies guys! That's what I'm talking about. I've decided to hold off on this for now though and get my car repainted first. Then I'm just gonna get my LT1 built up. Thx for everybody's time. It really helped me.
bonniew
Events and Cruise Spots
Jan 18, 2015 01:14 PM
chuyz28
Jan 15, 2015 04:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
Jul 4, 2005 05:00 PM
