Help!! 355 in my 90 mustang coupe.
Old Aug 4, 2002 | 04:10 PM
BOOST FED 95Z's Avatar
Post Help!! 355 in my 90 mustang coupe.
My friend has a 90 mustang coupe. He is putting a SBC in it and was wondering about the motor mounts. Has anyone seen this done or had experience with this. All help would be appreciated. This is NOT going to be a fuel injected car. Any other things we should look out for along the way. This car started out as a 4 cylinder. Thanks
Scott
1995 MYSTIC Z28
M6
T-TOPS
CHROME Y2K VETTE WHEELS
VORTECH S-TRIM
AFTERCOOLER
CC306 CAM
1.6 RR'S
HOOKER LT'S
MUFFLEX 4"
CHASSIS ENGINEERING 8 PT.
HARWOOD 2.5" COWL HOOD
NITTO 275-40-17 DR'S
Old Aug 4, 2002 | 04:41 PM
KTamez's Avatar
Post
It'd be easiest to change the K-Member. PA Automotive can make one for a direct Bolt-in.
http://www.paracing.net/
I believe Lemons makes headers for this swap also, about $850 though....
http://www.lemonsheaders.com/frames.html
Kurtis Tamez
LT4-396.com
97 Z28 LT4-396
94 Firehawk LT1-396
Team NW F-Body
Old Aug 4, 2002 | 05:01 PM
Post
Thanks for the info. Keep in coming guys.
Scott
1995 MYSTIC Z28
M6
T-TOPS
VORTECH S-TRIM
AFTERCOOLER
CC306 CAM
1.6 RR'S
HOOKER LT'S
MUFFLEX 4"
Old Aug 4, 2002 | 08:04 PM
Soma07's Avatar
Post
Ok, now im curious. What advantage would you gain by putting a SBC in a Mustang?
Jason
93 TA, M6
Old Aug 5, 2002 | 09:28 AM
Post
Its not for me, my roomate is in the process of this. He has always liked the looks of the 87-93 coupe, plus they have a big weight advantage over an f-body.
1995 MYSTIC Z28
M6
T-TOPS
VORTECH S-TRIM
AFTERCOOLER
CC306 CAM
1.6 RR'S
HOOKER LT'S
MUFFLEX 4"
Old Aug 5, 2002 | 11:25 AM
MissedShift's Avatar
Post
Plus, itll **** off every mustang guy within 50 miles.
Old Aug 5, 2002 | 01:06 PM
Post
This is correct, there will be plenty of pissed off mustangs.
1995 MYSTIC Z28
M6
T-TOPS
VORTECH S-TRIM
AFTERCOOLER
CC306 CAM
1.6 RR'S
HOOKER LT'S
MUFFLEX 4"
Old Aug 5, 2002 | 07:02 PM
Soma07's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by BOOST FED 95Z:
</font>
Thats cool but im wondering is there some inhertant advantage in using a SBC I dont kow about? It seems there are just as many parts available for the SBF as the SBC so couldnt you just build a 347 stroker and be done with it? That seems alot easier than using a bunch of custom parts.
Good Luck!
Jason
93 TA, M6
Old Aug 6, 2002 | 09:05 AM
Post
He isnt in to ford, he just likes the looks of the coupe. Doesnt care much for Ford products. Plus it is something different that you dont see everyday. You see SBC and SBF all the time but not harldy ever a SBC in a ford. And it will be fun pissing off the die hard ford fans
1995 MYSTIC Z28
M6
T-TOPS
VORTECH S-TRIM
AFTERCOOLER
CC306 CAM
1.6 RR'S
HOOKER LT'S
MUFFLEX 4"
Old Aug 6, 2002 | 11:25 AM
dougg01's Avatar
Post
Dude I used to know well, helped out, and even drove the car some had a fox body with a 355 and a glide.
Headers were custom units dumping behind the front tire.
Motor mounts were all home-made using flat stock and solid, GM mounts.
The rest was not a big task.
I think the car weighed 2,800lbs dripping wet.
4.30s, firestone 30x9s, fully tinned.
It was quick. Wheels up hard on the 'brake, 6.70s in the 1/8th if I remember correctly.
painted the engine blue. bluer anodized valve covers. GM folks loved it. Ford folks wanted to strangle him. Go figure. The car is sitting, rotting somewhere Gulfport, Ms now. Last I heard anyway.
Why....?
sm blk chev stuff is cheap, plentiful and almost every parts store in america has stuff for you. Plus, at the track, you can always borrow a spare with little fear of it not quite fitting. Most others have some fittement problems from motor to motor, year to year. GM kept this mickey-mouse crap to a minimum with the standard sm blks.
As for a 'glide.....everyone runs one and there are adapaters available and used everywhere for everything.
Old Aug 6, 2002 | 11:58 AM
Post
Doug,
that was a big help, I think this will be fun. So everything was pretty much easy except for the mounts? Who custom made the headers? Thanks for the reply.
scott
1995 MYSTIC Z28
M6
T-TOPS
VORTECH S-TRIM
AFTERCOOLER
CC306 CAM
1.6 RR'S
HOOKER LT'S
MUFFLEX 4"
Old Aug 6, 2002 | 06:57 PM
Soma07's Avatar
Thumbs up
Cool, thanks for the info! I guess there are advantages to running a SBC since you have 60million other SBC's to borrow parts from
Jason
93 TA, M6
Old Aug 6, 2002 | 07:09 PM
Slow95T/A's Avatar
Post
I don't know what exactly he is tring to build but You get some motor plates http://www.jegs.com/cgi-bin/ncommerc...19&prmenbr=361 This will might help with header selection. Although they kinda involved putting them in but he is putting a chevy in a mustang.
By the way I love that body style as well. I would like to put a LS1 in one.
Z Power
Sep 19, 2015 11:19 PM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
STEPHEN JOHNSON
Sep 7, 2015 02:28 PM
NewsBot
Jul 8, 2015 06:47 PM
