700R4 rebuild, where did i go wrong??
Old Aug 27, 2002 | 08:03 AM
john-e-boy's Avatar
Post 700R4 rebuild, where did i go wrong??
OK disappointment just set in, I just installed my 700R4 after I rebuilt it. I started the car and I could hear a clicking sound. I go through the gears and find out I don't have reverse. Where did I go wrong??
Also how many quarts should it take after a rebuild??
I put a new stock converter in, are you supposed to fill it with tranny fluid?? I filled it as much as I could to the point where some spilled out as I was putting it on.
Please help,
John
Old Aug 27, 2002 | 11:16 AM
john-e-boy's Avatar
Post
I would delete this but it was a good learning experience for me.
Found the clicking noise, it was an improperly installed flywheel dust cover (i can be such an idiot sometimes)
it wouldn't go into reverse because it didn't have enough tranny fluid. It took almost 9 quarts, thats quite a bit more that the capacity chart says in the chilton manual!
now my only question is how long will it take to find out if I messed anything up?
My excitement is up again, THANK YOU to everyone who helped guide me through my first tranny rebuild, SINCERELY!!
Thanks again
John
[This message has been edited by john-e-boy (edited August 27, 2002).]
Old Aug 27, 2002 | 10:27 PM
OneFlyn95z28's Avatar
Lightbulb
Well if it was totally dry It should take 11Qts.
Good luck man!
Ellis
Team Captain
Team North West F-Body
www.teamnwfbody.org
Old Aug 29, 2002 | 03:00 PM
xxsaint69x's Avatar
Post
i thought it was 12 qts with the stock TC.
Bolt-On 95 Z28 A4
See the Z
LT1Tech.com
Old Aug 30, 2002 | 08:22 AM
1989gta's Avatar
Post
just check the fluid color, if you did everything right it will continue to stay red for quite some time.
TGGodfrey
Aug 18, 2015 06:08 PM
Cam's maro
Aug 11, 2015 07:45 AM
Z28-50
Aug 7, 2015 01:22 AM
wesley81
Jul 27, 2015 11:31 AM
