64cc VS 70cc Combustion Chamber
Old Dec 25, 2002 | 02:00 AM
99huggerorangeZ's Avatar
Question 64cc VS 70cc Combustion Chamber
i am looking to buy new je pistons and a set of edelbrock victor jr cylinder heads but i am not sure whether i want 64cc or 70cc cylinder heads
i dont want to go any higher than 10.1 CR and je recommends me going with a 70cc combustion chamber with this piston(10.3:1) if i dont want to go above 10.1
BUT
what will i experience any performance difference between a 64cc combustion camber and a 70cc combustion chamber?
Old Dec 27, 2002 | 11:21 AM
Mindgame's Avatar
Just comes down to shrouding. On a standard angle valve centerline you will probably have better deshroud around the intake valve with the larger chamber. Then again, it all depends on where the extra volume was added? Is the chamber just deeper or what? I don't have an answer to that question but that might be something to ask before you buy. Don't know much about the Vic Jr's.
Best of luck.
-Mindgame
Old Dec 29, 2002 | 11:24 AM
HeavyChevySS's Avatar
Post
There are alot of specifics that need to be answered like the ones in Mindgame's post.
But the general rule of thumb is ...the higher the compression; the higher the HP/TQ output. 1 point of compression = 4% of power.
Ex: 10:1 compression engine putting out 400HP
this same engine at 9:1 would be putting out approximately 16 HP less!
Heavy
Nayr
Mar 3, 2023 08:34 PM
RUENUF
Mar 13, 2016 03:37 PM
realistyc
Jul 28, 2015 07:32 PM
RX Speed Works
Jul 24, 2015 02:25 PM
Duke79Zer
Advanced Tech
Sep 23, 2002 05:20 PM
