408 turbo LT1
Old Oct 7, 2004 | 12:23 PM
  #31
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
Re: 408 turbo LT1
Originally Posted by crash4cyl
The hole reason we started with the LT1 idea is the kid that owns the car gets a lot of heat from guys we know about owning a "Dog"...They all have the LS1's and they think that no LT1 can keep up. Then the ones that do they're too scared of because they sound like race cars. So the Idea is run a Turbo car that doesn't make too much noise on the street but is still incredibly fast for what it is. And I have a little bet going on with one of the guys at Speed Inc. as to this car vs. his New N20 Motor he's building for his car (it's already gone 9.80's). So it's a combo of friendly bets and rubbing it into peoples faces with an LT1. The car we're doing this to has already run a best of 12.17 @ 115ish. All it really has is bolt-ons and a 150 shot. He made his first bottled pass and he wanted to go faster. We're also "toying" with the idea of spraying until the turbo spools....depends on how the car launches though. As it is now, the thing still has a completely stock suspension...including the front sway bar.
Chris
mongse1--what would be the easiest way to get ahold of ED to talk cams with him?? thanks chris
Don't you work for Dudes performance?
Good luck with your project, we're ready when you are.
Old Oct 7, 2004 | 01:33 PM
  #32
crash4cyl's Avatar
Re: 408 turbo LT1
Actually I used to work for Dude's...they laid me off because they couldn't afford to pay me, even though I got them half of their F-body customers...And My friendly bet is with Pat...Ask him....we were talking a few weeks ago about it and he said he wanted to get his new motor done first. I think it'll make for some fun racing, seeing a N2O car go against a turbo car. All in good fun, infact I was over there a couple weeks ago discussing fuel systems with Mike, since I Liked what I saw in the tank and stuff. But thanks for the luck...we'll need it to try and get this done by next spring.
Chris
Actually you INTMD8-recommended his converter, shift kit, and trans cooler upgrade.....Works really nice behind the 150 shot...12.17 @115, totally stock suspension. Too bad we're gonna use a 400 with a brake to handle a little more abuse than I think the current A4 will like.
Old Oct 7, 2004 | 10:27 PM
  #33
mongse_1's Avatar
Re: 408 turbo LT1
I e-mailed Ed and worked up specs via e-mail. He's one of about 4 people who know my entire setup. You can try calling him. We've called him in the past for Mustang cams.
1-3/4" primaries will work perfect if you've got a 1.60 exh. valve. Normally, you try to make the primaries 10% larger than the exhaust valve.
Old Oct 8, 2004 | 09:20 AM
  #34
crash4cyl's Avatar
Re: 408 turbo LT1
thanks, as you can tell we're not too worried about who knows this set-up. And I was hopeing the 1 3/4 would work but I've got this strange feeling they may not be big enough....only because of the HP levels this turbo is capable of. But I suppose if we really crank the boost we'll probably shatter the block. So I guess being restricted in how much HP we can flow will keep the motor alive a little longer
BTW will the PTK kit bolt up to a PT-96 Garrett?? I've tried asking they keep telling me to call them and I really don't have the time between work and family right now.
Old Oct 8, 2004 | 09:41 AM
  #35
JZ 97 SS 1500's Avatar
Re: 408 turbo LT1
No it will not bolt up. The 96 is a T6 flange, the PTK system uses the standard T4. If you want an LT1 PTK kit, they will direct you to myself. So feel free to e-mail me with any questions.
Jose
Old Oct 8, 2004 | 09:48 AM
  #36
crash4cyl's Avatar
Re: 408 turbo LT1
pm sent
Old Oct 8, 2004 | 01:41 PM
  #37
crash4cyl's Avatar
Re: 408 turbo LT1
Well just did some reading on a single plane intake on an LT1...very nice. I'm thinking I would rather do that than try to get a 58mm Tb to flow the air I'd like. I can switch to the 215cc race heads and go with a Victor E single plane....everything's ready to go and I can put a 4 barrel 2000CFM T/b on it and get a little more flow. Plus the 215's flow better than the 227's. So current status
383
scat 7000 crank
oliver 5.7 rods
J/E forgings for 9.5:1
AFR 215 Race heads
Victor E intake
Edel. 2K cfm t/b
PTK Turbo kit probably with a Garrett gt47-88T turbo and air to water intercooler.
Plus the cam....still no idea....
How's it coming guys??
chris
Old Oct 8, 2004 | 08:25 PM
  #38
97WS6SCharged's Avatar
Re: 408 turbo LT1
You'll have better luck sending Jose an e-mail instead of a PM.
Also, the 1 3/4" should be more than enough header for the car. Anymore than that and the turbo will start to become sluggish.
Old Oct 12, 2004 | 12:47 PM
  #39
crash4cyl's Avatar
Re: 408 turbo LT1
I'm thinking I may just keep the PT-96 as it leaves a little room to play with boost and HP #'s....I'll just have to change the Flange on the PTK kit and maybe move the radiator a little. All of which isn't going to be a big deal as it sounds since it will be mostly a race car. Fun-Fun. I guess all that's left is the cam...yeah!!!
Chris
Old Oct 17, 2004 | 10:41 PM
  #40
SSnthe10s's Avatar
Re: 408 turbo LT1
that converter sounds a little big i would think a 3800-4500 at max
Old Oct 18, 2004 | 04:06 AM
  #41
sleeperz28's Avatar
Re: 408 turbo LT1
Chris
The Lt1's cant keep up
The last time I looked the Afr 215's were like $1,000+ more then a 220 or 227. You wont need these heads to make the power you want, but it might get you there faster. The 1 3/4 primary tubes will be fine, thats what i use. I run 2 3" down pipes and dump them at the axles. I would think that with a TH400 my car would be in the 8's. However, its a street car and a daily in the summer, so I kept the 6spd.
Old Oct 18, 2004 | 04:39 PM
  #42
crash4cyl's Avatar
Re: 408 turbo LT1
I'm going to talk with Midwest out here about the converter, they'll fix it if we put it in and it doesn't work like we want it to. And Can the LT4 Intake really keep up with all this CFM??? Actually can the T/B keep up with all the CFM I need it to flow for this motor?? That's the big worry I have right now.
Chris
Old Oct 18, 2004 | 10:17 PM
  #43
sleeperz28's Avatar
Re: 408 turbo LT1
LT4 intake with a mono blade T-body supports 1200hp with my setup..It will work for what you want to do.
Old Oct 19, 2004 | 10:57 AM
  #44
crash4cyl's Avatar
Re: 408 turbo LT1
But will it make as much HP as a single plane?? I can have a sheetmetal version made dirt cheap, and add a 4 hole 2K CFM T/B. I'm pretty sure the SP will out flow the LT4 intake & T/B.
Old Oct 19, 2004 | 01:28 PM
  #45
sleeperz28's Avatar
Re: 408 turbo LT1
Your question was will the LT4 intake/T-body keep up with this cfm. I answer the question, yes. I already made the kind of power your looking for with it. I also dont see why I couldnt push it to 1300hp if I wanted to....
