400+ci chevy owners...how big can you go...
Old Oct 6, 2005 | 09:37 PM
Kurt Crosbie's Avatar
...with a stock block? I found that thy are having deals on 4340 400 stroker cranks on ebay right now and figured it may be the time to build another motor or at least buy a crank, but I dont want to buy one that is loo long to work in a factory block. I may be wrong, but I've heard that some big cranks are too long to fit in a factory block...? Anyway, how much crank can I stuff in there? I'll be changing everything including the pan and clearancing isn't an issue. I want to go 4.125 if possible, but there are 4.1 and 4.0 cranks available too.
Old Oct 6, 2005 | 09:48 PM
markinkc69z's Avatar
Re: 400+ci chevy owners...how big can you go...
You can probably go 4" with major grinding along the pan rails and bottom of the cylinders but you'll need a Rocket block or equivelant with wider pan rails to fit a longer stroke. A small base circle cam will be necessary.
NewsBot
Apr 8, 2015 06:08 PM
NewsBot
Mar 16, 2015 12:51 PM
CARiD
Dec 26, 2014 04:20 AM
formula79
18
Jul 1, 2002 02:39 PM
