40/60 Valve spacing rockers/shaft mts?
Im looking for a set of shaft mount rockers for my heads which have a 40/60 valve spacing, any off the shelf sets that anyone knows of. If I can't find a set is there a roller rocker that will clear a 1.55 spring and can hold 600lbs of pressure?
Re: 40/60 Valve spacing rockers/shaft mts?
What heads are you running with a 60/40 split? AFR 227s? Brodix Track I-Xs?
Dave
Im running a Track1x, where would you draw the line with spring pressures between a shaft mount setup and a roller rocker setup to justify the cost?
I am using a setup from this company .they build shaft systems for a lot of race teams and some of the major suppliers.
www.dreracing.com
www.dreracing.com
DRE's makes Comps Shaft Rockers from what I understand. I was interested in more information concerning their product, but their website definitely leads much to be desired.....have of it doesn't work....more importantly the SBC applications listing doesn't work.
Dave
Dave
What is 40/60 spacing?, ie what is the
spacing betwen valves, also the offset of the intake
valve vs the cyl center line.
Same questions, standard spacing.
Lifter bores, what is the spacing, and
offset, from cyl center line?
I am a dealer for DRE and you can buy direct and if need be they can make you most anything you need.
I have 600# of prsesure on the nose and will be spinning to 7600 rpm or so, think stud mounts will hold with this sort of pressure?
are these numbers correct?
the lifter bore spacings, seem goofed up
http://www.crossfire.homeip.net/tech/eng5.gif
14
Aug 11, 2015 12:03 PM
RX Speed Works
Jul 24, 2015 02:25 PM
