396 LT1 clearance/rotating assy. questions
Old Nov 13, 2003 | 04:31 PM
  #31
rskrause's Avatar
Moderator
Re: Re: Talked to Callies
Originally posted by OldSStroker
It's been said that nitrous, boost and cocaine are about equally addictive. Probably a cost parallel there, too.
Using nitrous on a boosted engine: is that cross-addiction?
Bret: the pistons will need to be custom in any case, due to 10 over size, but JE wasn't too keen on the partcular combo of the crown whch I want to use and the short compression height.
Rich Kraus
Old Nov 13, 2003 | 05:54 PM
  #32
SStrokerAce's Avatar
Yeah for what you are looking at the most you could really run with a 3.875" stroke is about a 5.850" rod. Might as well go with the 5.7" rod.
Bret
Old Nov 13, 2003 | 06:08 PM
  #33
jimlab's Avatar
Rich, if you don't mind me asking, why are you limiting yourself to a 0.010" overbore? The wide range of pistons available for a 0.030" over bore would make this a lot easier, obviously, and there'd still be enough left to clean up the block with another small overbore if it ever needed to be rebuilt. Are you simply trying to maintain the maximum amount of cylinder wall thickness possible?
Old Nov 14, 2003 | 08:42 AM
  #34
Originally posted by jimlab
Rich, if you don't mind me asking, why are you limiting yourself to a 0.010" overbore?...............
That's my thinking
Old Nov 14, 2003 | 09:30 AM
  #35
The Big Show's Avatar
I caught this thread kinda late but its kinda interesting. I know if I had it to do over again, I would have gone a little different route. I have the Carillo rods with the oiling to the wrist pin. As trick and strong as they are, they are killer huge and made the 3.750 stroke combo a nightmare for clearancing. We already hit water so I had to make that call to Jeg's for some hardblok which I was going to use a bit of anyway but not to the extent I will now cause this is still a street car. If I didn't have so much in my pistons and cam I would have just scrapped the block and gone back with a stock stroke and a different cam so I could still utilize the rods.
If I was boosted it would be a no brainer to stay with the stock stroke so I could utilize a beefy piston and beefy rod. As much as I like the LT1 I'm almost positive this will be my last go round with it. The dom's are beggin' for some cubes and the LT1 block just can't get me where I want to be.
Old Nov 14, 2003 | 02:40 PM
  #36
rskrause's Avatar
Moderator
Jim: yes, it's to keep the cylinders as thick as possible. Will 0.020" make a difference? Probably not. But the pistons I am going to use can be had 0.010" over, so why not?
Bobby: I thought about reverting to a stock stroke, but the block is already clearanced and I was planning on a partial fill anyway.
Rich Krause
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
cmdeshon
Dec 27, 2014 10:06 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
97_396_WS6
Aug 4, 2002 10:23 PM
