22psi at idle?
Old Jun 14, 2005 | 11:12 AM
Gripenfelter's Avatar
22psi at idle?
Using Quaker State 10W40 dino oil. Car has less than 50 miles on the new motor. Hasn't seen more than 2500rpm.
I'm seeing 22/24psi at idle when the car is hot.
I have a Canton oil pan with a stock volume pump.
Should I change to a thicker oil?
Engine builder said he was building a bit on the loose side because his SBC circle track motors live longer that way.
Old Jun 14, 2005 | 12:57 PM
Zero_to_69's Avatar
Re: 22psi at idle?
I see nothing wrong with 22# at idle (~900 RPM?)
My stock pump with black pressure spring produces about 20 PSI at
800 RPM and up to 45 PSI @ 6000 RPM (all at operating temp.)
Old Jun 14, 2005 | 02:59 PM
12Second3rdgen's Avatar
Re: 22psi at idle?
Sounds normal to me with a stock pump.
Old Jun 14, 2005 | 03:42 PM
Re: 22psi at idle?
Thanx guys. Just a worry wort here.
68camaroboltz
Oct 5, 2015 01:46 PM
Double aught
Oct 2, 2015 11:29 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
autoxr166
Sep 25, 2015 04:21 PM
