1.8" spring recommendation for cam
Old Apr 18, 2006 | 10:31 PM
  #16
Stephen 87 IROC's Avatar
Re: 1.8" spring recommendation for cam
With longer valves you'll need longer pushrods. You'll need to use a checker to find the length you need. You can't guess at the length. .100" longer valves doesn't always mean you need .100" longer pushrods. Lash caps, if there's enough valve stem above the retainer locks to use them, will add even more height to the valve stem that the tip of rocker sits on.
Checking all the measurments. There shouldn't be a problem but make sure the bottom of the retainer doesn't hit the top of the valve guide/seal at full lift.
QuickSilver02
Apr 7, 2015 11:12 AM
carl.froehlich
Mar 13, 2015 12:38 AM
Queens94z28
Nov 20, 2014 06:03 PM
Don 97 SS
Jul 11, 2005 08:50 AM
