WOW, talk about a better idle
Old Oct 3, 2003 | 04:27 PM
Pro
Guest
Posts: n/a
I installed a MSD 6A and it's coil.... damn.... talk about quicker starts, smoother idle (idles about 100-200rpm higher though), no surges, etc.
I did the same on my truck like 3 years ago. I had the same results, but no where NEAR as nice as what the Camaro experienced.
Still havnt upgraded wires or replaced the plugs yet. Need to do that ASAP. Damn thats gunna suck.
Old Oct 3, 2003 | 08:16 PM
lordmetalz28's Avatar
any better feel to it after installing quicker accelration, throttle response
Old Oct 3, 2003 | 11:46 PM
Pro
Guest
Posts: n/a
Not sure, I havnt drove it yet. I cant find a good place to mount the thing (I think I have decided on drivers side upper firewall). Until then, the car will probably just sit.
Old Oct 3, 2003 | 11:48 PM
doug791's Avatar
awesome man! I'm thinking about getting the msd 7 the one thats fully programmable because i want to be able to mess with everything on my car. Let us know how she runs once it all gets bolted up.
Old Oct 7, 2003 | 04:27 PM
Pro
Guest
Posts: n/a
Ok well I finally got it all hooked up (I wanted it to look at least somewhat nice, and havnt had much time to finish it). I just got done driving it. Idle and throttle response was much better (much more so than when I put the exact coil and box on my truck 3 years ago).
I still havnt even changed the wires, plugs, cap and rotor yet on this car either.
I wasnt looking for performance (even though Im sure there is some change). Besides it has like 170k miles on it.
Guess I will know about gas mileage later on down the road. It didnt make a difference on my truck.
Old Oct 7, 2003 | 09:35 PM
Damon's Avatar
I have found that an ignition amplifier setup (like MSD and others) usually makes an "oh wow" kind of difference only if the original ignition was kinda worn out to begin with. Having a wicked strong spark covers up a multitude of sins. A marginal coil will suddenly fire like a nuclear reactor with an MSD strapped to it.
The one truly back-to-back expereince I had switching from a standard GM HEI in perfect condition (along with fresh plugs and wires) to the MSD netted a slightly smoother idle (maybe 25 RPMs faster), slightly better starts, no difference in power (probably a few HP on a dyno- no seat-of-the-pants difference) and about 1 MPG improvement in mileage (from about 14 to 15 in a mild performace street setup). Better for sure, but probably not the bang-for-the-buck champ.
I usually don't use them unless I'm going to run boost or nitrous- where the difference is more dramatic since you have to jump the gap against massively higher cylinder pressures.
NewsBot
May 24, 2015 10:50 AM
Magenta_Hearts
Mar 5, 2015 07:01 AM
edman
Jan 22, 2015 02:45 PM
Pentatonic
Jul 29, 2002 11:21 PM
Brady
Jul 29, 2002 10:30 PM
