won't hold and idle..
Old Dec 29, 2004 | 10:59 PM
importkiller1's Avatar
I have an 87 iroc that won't hold an idle. The computer comes up with the code 34. If I remember right it's saying that I have high manifold pressure. Any idea's?
Old Dec 30, 2004 | 12:35 AM
V8Rumble's Avatar
Re: won't hold and idle..
Hmmm. I've seen code 34 referenced here, here, and here (of course you might prefer the PDF version...).
I also found this:
CODE 34 (MAF SENSOR VOLTAGE LOW)
Thoroughly inspect the vehicle for sources of air entering the engine without passing through the MAF sensor. Specifically, look for a cracked, cut or loose duct between the air meter and the throttle body, poor inlet runner to plenum or manifold sealing, a split PCV hose or any type of vacuum leak. A large quantity of air does not necessarily have to be involved. If any leaks are found, repair the condition, clear the codes and check if the code resets.
So you might look for any air leaks after the MAF, aka "false air".
HTH!
V8Rumble
Old Dec 30, 2004 | 01:30 AM
aklim's Avatar
Spray brake cleaner on the hose a little before the MAF and even on the MAF all the way to the TB. Make sure your hoses are also good. As a last resort, try a gentle spray of electronic cleaner on the MAF filaments.
Old Dec 30, 2004 | 05:21 PM
I'll try that and see what happens. Thanks.....
JJOHNROE
Parts Wanted
Oct 23, 2015 02:03 PM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
rideordie
Sep 7, 2015 08:22 AM
