wires with headers question
Old May 17, 2004 | 08:22 PM
lordmetalz28's Avatar
ok so im ordering my headers tommrow my question is will my 8.8 accel wires be ok or should i get the wire wrap and boot covers, the boots are thick and look to be tough but just wondering. i picked up a starter shield to, just really wondering on this wire issue. i dont need wires melting. thanks
Old May 17, 2004 | 08:33 PM
TheGreatJ's Avatar
If the headers are coated and the wires don't touch them you'll be fine. With uncoated headers, I'd run heat shields at least on the plug wire boots.
For what it's worth, when I went from manifolds to headers I picked up a set of cut-to-length wires with 90* boots and ran the wires UNDER the headers and around the back of the heads. It's a much cleaner look and it keeps the wires off the primary tubes.
Old May 17, 2004 | 09:37 PM
yes the headers are hedman coated and i guess i will need the looms or separators to run the under the headers.
Old May 17, 2004 | 11:12 PM
krazzycowgirl's Avatar
I just found out today when I got my car back that the headers I ordered came with a kit to size the wires & stuff for the sparkplugs. Of course I use Taylor wires for my car.
Old May 18, 2004 | 05:15 PM
what kinda headers
Old May 18, 2004 | 05:17 PM
I got the Eldbrocks from Summit racing
Old May 18, 2004 | 08:40 PM
great just great, after a month of soaking bolts to prepare this header install i found out today i have been soaking the nut on the stud that threads onto the stud itself, there is no way to lube the bolt then cause its threaded into the head, unless convection is taking place., am i fuc$ked
Noenav
Mar 1, 2019 07:38 AM
89 iroc zl1
Jan 14, 2015 02:18 AM
lbrowne
Nov 13, 2011 04:25 PM
Jul 4, 2005 05:00 PM
GigaMp3z
Feb 20, 2003 02:57 PM
