will this work?
Old Jan 17, 2003 | 01:29 PM
Dan88Iroc's Avatar
will this work?
My Dad has a 95 Z-28 convertible that he put new gears in last summer. His stock gears were 2.73's and he switched in 3.73's. They are Richmond gears if that matters. Anyway, they whine and he wants a quieter car so he told me he was switching them out and that I could have them to throw into my car for free if I want them. My questions are:
1. Would they work in my car? I have the stock 2.73's in there now. The rest of the cars description is in the sig. I can't check anything else right now about the rear end because the car is in storage quite a ways away.
2. Do I need to buy anything else to make the swap easier or possible even? I have a buddy that knows how to swap gears, its just a matter of getting the gears from my dad and getting them over to my buddies.
3. If I decided to have a mechanic do them how much would this cost?
4. How do I calibrate my speedo to work with the new gears?
5. Is there anything else I have forgotten or left out?
Old Jan 17, 2003 | 02:10 PM
aklim's Avatar
1. Yes
2. Gear Change kit from Jegs or Summit. Includes all the bearings and seals you will need.
3. I'd get a mechanic and see how much he charges because without the right tools, it is impossible.
4. New drive and driven speedo gears from GM
5. Need to check with the guy who installed the gears in Dad's car. Using GM specs WILL NOT cut it. We have tried that and the gears howl. You will have to use Richmond's method and specs to install. Also check with them if it can be resused in another car. They may have helpful hints. This is necessary because the gears may have been installed wrong or whatever the first time and developed a wear pattern.
Old Jan 17, 2003 | 02:13 PM
aklim's Avatar
Drive Gear: 15 tooth Part 8642620 Gray color
Driven Gear: 45 tooth Part 25513052 Light Blue
Old Jan 19, 2003 | 08:50 PM
brodyscamaro's Avatar
i paid 90 bux for a gear and carrier change. what gears do you have in your car now? did your dad change the carrier in his car?
Old Jan 31, 2003 | 02:31 PM
Dan88Iroc's Avatar
I have the 2.73's now, and I believe that he did not change the carrier in his car
Old Jan 31, 2003 | 02:36 PM
TheGreatJ's Avatar
He probably just got the thicker ring gear...in which case you can use your 2.73 carrier and it'll bolt right on.
Incidentally, the reason they whine is because Richmond uses a steeper gear pitch than GM which makes the gears stronger and whines as a side effect.
Red Hawk 94
Mar 18, 2019 04:03 PM
blac94Z
Feb 18, 2015 11:36 AM
squarehead
Jan 15, 2015 07:02 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
